Today I learned how thin dodge lays their paint.
Old 11-11-2013, 06:15 PM
Prismatic's Avatar
Prismatic
Prismatic is offline
Default Today I learned how thin dodge lays their paint.
Had some clear coat issues I was trying to knock down. Sanded the clear with 1500 grit, and almost immediately hit primer.
Oh well, that area needed paint anyways. But still, I honestly think they only applied one coat of paint.
Old 11-12-2013, 09:27 PM
Will_V2Lab's Avatar
Will_V2Lab
Will_V2Lab is offline
Same on my 04. I noticed a scratch on the top of the bedside and its to metal but the paint around it is incredibly thin compared to other cars i've had.
Old 05-23-2014, 11:21 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Paint should always be thin. You only want enough paint to cover the primer.
However, your clear coat should be thicker. A good custom or after market paint job will have 3-4 clear coats and one cost usually sanded off during the cut/buff/polish stage.
Kandies, pearls and other more exotic jobs will have more
Old 05-26-2014, 09:27 AM
rebeltaz83's Avatar
rebeltaz83
rebeltaz83 is offline
Very true, having 14 years of plus experience doing body work, and mechanical work...... 3 coats of paint, dusted on, and the clear coat is usually put on pretty thick, right on the edge of running just about, and then sanded with 1500 wet, dried, buffed with a high rpm professional buffer, and then polished to sheer high gloss, you can see yourself to shave kind of finish.... thats for an all over paint job that you want to look good, sanding and buffing merely rids the "orange peel" look from the factory. collision jobs, we mostly leave it after the clear coat to match the rest of the car. once in a while we will sand and buff, but for the most part they turn out very nice without having to sand and buff.
Old 05-26-2014, 09:32 AM
rebeltaz83's Avatar
rebeltaz83
if you shop around you can find 3000 grit paper, but make sure you do it wet, leaves a more finer etch, doesn't take much it's a very delicate process.
Old 05-26-2014, 11:47 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
LoL.
I just painted a bike where we set sanded the OEM fairings, laid a gold 2K primer sealer, Guacamole green, intercoat with House of Kolor Ice Gold Pearl and 4 coats of a high solids clear. Already started wetsanding the clear on some pieces. Absolutely beautiful.
Old 05-26-2014, 01:16 PM
rebeltaz83's Avatar
rebeltaz83
LoL.
i bet that looks sweet!!! got any pics.?
Old 05-26-2014, 01:25 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
But of course. They are on our Facebook though
The couple of pieces you see with a pattern on them do not have HoK flake but are hydro dipped with as pearlescent based film
https://www.facebook.com/TrickedOut....9154742&type=1
Old 05-26-2014, 01:31 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
2K gold sealer, Guacamole green, hydrographic pearlescent film on top, high solids clear coat (not wet sanded and buffed at time of video)
Old 05-26-2014, 03:57 PM
rebeltaz83's Avatar
rebeltaz83
VERY, VERY NICE!!!! they always look better in the sun, lol
Quick Reply: Today I learned how thin dodge lays their paint.
