Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
Tranny slip
Old 11-07-2013, 10:49 PM
kefreeman39's Avatar
kefreeman39
kefreeman39 is offline
Default Tranny slip
Have a 86 ramcharger and tranny slip when it's cold. After it warms up everything is fine? Any idea's
Old 11-09-2013, 02:07 AM
moe7404's Avatar
moe7404
moe7404 is offline
how cold is it on start up? does it delay engagement when cold? i have had 727s when cold and the filter clogged a little delay engagement going into rev. it delays going into rev cause rev requires very high pressure. a new filter fixed it. i have found a very good external filter.
most chrysler fluid lines are 3/8. and ALLWAYS use steel tubing, and high pressure hose if needed. most chrysler trans the fluid goes in to the trany on the left at the rear.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
Quick Reply: Tranny slip
