Mysterious hose - can you tell me what it goes to?
Old 11-03-2013, 06:06 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
1997JollyGreenGiant is offline
Default Mysterious hose - can you tell me what it goes to?
I have this mysterious hose in my truck and I don't know what it goes to. It can be seen below:
Anyway, the truck won't shift past second gear, could this be related?
Old 11-03-2013, 07:04 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
looks like the dipstick tube for the tranny? maybe u lose all ur fluid.
Old 11-03-2013, 07:09 PM
1997JollyGreenGiant
No, I have my tranny dipstick hooked up. The fluid levels are in the proper ranges. Any other ideas? This thing has me stumped...
Old 11-03-2013, 07:20 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
well i mean it also kina looks like the tube that plugs into the top right side of the water pump... but no way its long enough to get down there. cant trace it and see where the other end goes?
Old 11-03-2013, 07:50 PM
1997JollyGreenGiant
I believe the other end goes to the top of the transmission or transfer case. I'm hoping it's transmission related and it explains why I can't get past 2nd gear! Thanks in advance for your ideas!
Old 11-03-2013, 07:54 PM
Probably vent tube for t-case.
Old 11-03-2013, 08:02 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Well, you need to get down and look more and take more pictures. We don't even know if you are on the driver or the passenger side. Definitely see a control arm.
It appears to be passenger side since looks like diff is far right side and away. Here is at least the mess of linkages on the tranny, but from the driver side.
My first guess is HeyYou's first guess.
Old 11-03-2013, 08:19 PM
BigRed14's Avatar
BigRed14
BigRed14 is offline
looks like there is a rubber line attached to the left side?
think its the vent tube for TC
Old 11-03-2013, 08:20 PM
1997JollyGreenGiant
Yeah, I should be more specific. I'm on the passenger side. I had the engine out and got it back in now, so I had everything disconnected. I've got just about everything hooked back up, just couldn't figure out this hose. The vent for the t-case makes a lot of sense though! Where would it normally be bolted up?
Thanks for the help!
Old 11-03-2013, 09:10 PM
BigRed14's Avatar
BigRed14
BigRed14 is offline
i cant for the life of me figure out how to copy the one page from the manual
but from the picture the bolt goes through exactly where the transmission fill tube is mounted on the upper transmission bolt to engine
im looking at my 2001 manual im not sure if it exactly the same
im sure someone will correct me
you can always go to the DIY section and download the manual. good thing to have
Quick Reply: Mysterious hose - can you tell me what it goes to?
