Offroad tire
Old 10-31-2013, 12:18 PM
Ramthis98's Avatar
Ramthis98
Ramthis98 is offline
Default Offroad tire
I have a 98 ram 1500 4x4 , currently i have a LT315/75R16 tires on, but its it possible to change it to LT285/70R16? The change is the 2 numbers which is the width
Old 10-31-2013, 12:21 PM
LT - Light Truck.
285 - section width. (widest portion of tire mounted on specified rim.)
70 - aspect ratio. Ratio of width, to sidewall height.
R - Radial tire.
16 - rim diameter.
You can certainly go with those tires, they will be a couple inches shorter, and a bit wider.
Old 10-31-2013, 02:17 PM
jkeaton is offline
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
^ less wide.
your current tires are 35 inches tall
285/70/16 are just under 32 inches tall and 1 inch narrower
http://www.1010tires.com/Tools/Tire-...5R16/285-70R16
Old 10-31-2013, 07:34 PM
Spillage's Avatar
Spillage
Spillage is offline
...285 - section width. (widest portion of tire mounted on specified rim.)...
I always thought this number was the average of the section width and the tread width.
Old 11-03-2013, 07:47 PM
Ramthis98's Avatar
Ramthis98
What bout LT275/70R16 using my stock rims?
Old 11-03-2013, 07:56 PM
Basically a 31" tire. 4 inches smaller than what you have now.
Quick Reply: Offroad tire
