Horn honks 3 times
Old 10-28-2013, 12:06 AM
RockGuardedDak's Avatar
RockGuardedDak
RockGuardedDak is offline
Default Horn honks 3 times
Just curious if anyone on here has had a similar problem and solved it?
Sometimes, when I hit the unlock button on my key fob, the horn will honk 3 times and stop. No more, no less. It's random when it does it, some days it won't do it at all, others it happens 5 or 6 times in a day. It's driving me nuts. For now, I unplugged the horns, but I don't like that (I use my horn quite frequently, alotta dumb drivers here). It only happens when I use the key fob, if I use the key in the door, it doesn't do it. If I can't figure this out by Thursday, I'm just gunna go get a spare key cut and stop using the keyless (only using the keyless right now to warm the truck up in the morning)
Old 10-28-2013, 12:24 AM
PublicHair's Avatar
PublicHair
PublicHair is offline
It's the security system. Letting you know someone has tampered with your vehicle.. Tho in my case and probably yours its more like a sensor gone bad.
Mine will honk if sat for three plus days which is common as I hardly drive my durango.
Someone suggested a bad door sensor (open door, there is a sensor that lets the vehicle know the door is closed).
Old 10-28-2013, 12:25 AM
PublicHair's Avatar
PublicHair
Oh yeah.. I simply disconnected my horn. I don't care to fix mine. It's now a second spare vehicle..
Old 10-28-2013, 12:53 AM
that_guy's Avatar
that_guy
that_guy is offline
I've never had any issues at all with mine, but apparently resetting the alarm has worked for a lot of people. https://dodgeforum.com/forum/1st-gen...going-off.html
Old 10-28-2013, 01:24 AM
PublicHair's Avatar
PublicHair
^your system is different. 01+ trims are more in depth
Old 10-28-2013, 06:46 PM
RockGuardedDak
I like having my horns cuz like I said, I use them a lot! But if it weren't my main vehicle, I would likely leave them un plugged as well lol.
I tried the reset on the security system, hopefully it works. It would make sense with mine cuz I originally bought it from an insurance auction. The truck was vandalized. Tomorrow will be the test as it usually does it first thing in the morning. Thanks for he insight!
Old 10-29-2013, 04:38 PM
RockGuardedDak
Didn't fix it. Don't know what will at this point. May just install a button and wire the horns to that instead
Old 10-29-2013, 07:10 PM
PublicHair's Avatar
PublicHair
Like I said, someone once told me its the door sensors. But my thought was if one of the door sensors is randomly going nuts not only would it trigger the alarm as stated but wouldn't it also randomly kicked on the interior lights while driving? My Durango is pretty much just a road trip vehicle and sees a lot of long period road time and I've never seen the lights flicker on inside at all.
..someone also said it could be the CTM. Now those do have a history of being nuts. You could go to car-part.com and locate one for less than $100 but problem is that unit also controls your keyless entry. So if you swap that unit out you'll also need to reprogram your key fobs..which could be expensive. Dealer down in Texas wanted $60 per fob. Dealer in Colorado wanted $25 for unlimited fobs programmed. ...if I could fix my issue for $60 (CTM) + $25 (keyless) then $85 doesn't seem too bad to fix the issue....
Quick Reply: Horn honks 3 times
