Sensor Idenification
Old 10-26-2013, 09:04 PM
im1986's Avatar
im1986
im1986 is offline
Default Sensor Idenification
I have a 2000 Dodge dakota, 4.7L, 4x4, auto trans.
I am trying to figure out what this sensor is? I was under the truck today and noticed the screw was missing.
The sensor is on the passenger side of the truck, front of the motor, from underneath.
can anyone identify it?
File Type: jpg
Old 10-27-2013, 01:05 AM
sl2racer's Avatar
sl2racer
sl2racer is offline
don't know what the sensor is but the screw holds the sensor on there so to not leak fluid. judgeing from the fluid on the sensor connection maybe a oil temp sensor??
Old 10-27-2013, 01:23 AM
magnethead's Avatar
magnethead
magnethead is offline
I sure don't know, but there has to be somebody on here that would. *cough*Mr. Sxr*cough*
Old 10-27-2013, 09:00 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Crankshaft Position Sensor 4.7
Old 10-27-2013, 09:07 AM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
Hey I looked at this thread and I had no idea... I was staring at the metal housing it was attached to and still couldn't get it lol.
Then Dakaz comes in and says its a Crank position sensor... MINE LOOKS LIKE THIS:
Old 10-27-2013, 09:12 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
sxrsil3nt
Just checked yes that's for the 3.9 he has the 4.7
Old 10-27-2013, 10:05 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
The location is "wrong" for the crank position sensor. He says "front" of the engine. The CPS is over the starter, just under a freeze plug, on the rear (tranny) side of the engine.
Can you widen out the picture a bit?
That looks nothing like my CMP. I can see that through the wheel well.
Old 10-27-2013, 11:14 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I now think its the Camshaft Position Sensor not the crank sensor
A good read http://www.garagejournal.com/forum/showthread.php?t=148309
Old 10-27-2013, 11:17 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Agreed. Camshaft position sensor.
Old 10-27-2013, 02:53 PM
im1986's Avatar
im1986
im1986 is offline
thanks for the replies. I found a bolt that threaded in to hold it in place. Could this be the cause of the dreaded "no bus" issue i have been fighting?
I just ordered a ECU yesterday before I found this sensor.
Quick Reply: Sensor Idenification
