transmission
Old 10-20-2013, 08:26 PM
mudpuddle's Avatar
mudpuddle
mudpuddle is offline
Default transmission
Hey guys finialy took my truck to a shop and he sayed he believes my shift silinoid is bad so I did it myself while under there I was wondering if the 2 valves are supposed to have a lot of play in them or not? I can move em up and down maybe a inch or so. Any idea how much play that should have ?
Old 10-20-2013, 08:37 PM
Are those the band apply pistons? Probably wouldn't hurt to adjust them up.....
Old 10-20-2013, 08:56 PM
mudpuddle's Avatar
mudpuddle
I'm not sure what they are I don't know much on transmissions myself I just didn't think it was good for them to be that loose. Another thing is is that the bolts on my valve cover were not that tight some only hand tight could that be causing a shift problem to?
Old 10-20-2013, 09:03 PM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
Do you mean valve body?
Yes loose valve body bolts could cause shifting issues.
Dave
Old 10-20-2013, 09:11 PM
mudpuddle's Avatar
mudpuddle
Yea the valve body. I wander if that's been the problem the whole time. Do u know what the gap should be for those valves?
Old 10-20-2013, 09:17 PM
xjarhead69's Avatar
xjarhead69
This is a good thread to read thru just to familarize yourself with the transmission and its parts.
https://dodgeforum.com/forum/2nd-gen...-progress.html
Also watch these video's of the transmission http://s809.photobucket.com/user/xja...46641714122307
Dave
Old 10-20-2013, 09:39 PM
mudpuddle's Avatar
mudpuddle
I didn't see in the post but ware does the connector go for the main solenoid? And how tight do those valves get tightened? But deffinatly helped figure out what I'm looking at under these.
Old 10-21-2013, 12:38 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
I suggest you take it to the shop and let them adjust the bands.
And please add ALL the info about your truck to your sig and profile. Thanks
Quick Reply: transmission
