Fuel level for fuel pump
Old 10-20-2013, 01:07 PM
TheBigRedTruck's Avatar
TheBigRedTruck
TheBigRedTruck is offline
Default Fuel level for fuel pump
I replaced my fuel pump about 1k miles ago. I've since kept the fuel level no lower than a quarter. I was wondering how low I can go before damaging the pump for the long run?
Old 10-20-2013, 01:33 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
I personally don't think it matters. The fuel splashes around anyway. Plus we are getting into the colder months.The sending unit might be more affected than anything else. Put some MMO in the tank once in a while. More importantly is what brand did you replace with?
Old 10-20-2013, 01:41 PM
TheBigRedTruck
What's MMO? I think it's a Spectre
Old 10-20-2013, 01:49 PM
zman17's Avatar
zman17
zman17 is offline
Marvel Mystery Oil. And the quality of the pump is directly related to how long it lasts, not the fuel level ,IMO. Mopar,Denso, Delphi are the recommended choices.
Old 10-20-2013, 02:03 PM
TheBigRedTruck
I never thought of MMO in the tank! I've heard of running it low causes the pump to suck in air instead of gas thus making it burn out
Old 10-20-2013, 02:16 PM
Received 3,206 Likes on 2,958 Posts
The problem with fuel level, as it relates to pumps, is that the pump is cooled by the fuel. So, at lower fuel levels, more of the pump is exposed, and doesn't get cooled as well it would like. You would have to run it at below a quarter tank for quite a while before it actually starts causing a problem though.
Old 10-20-2013, 02:17 PM
TheBigRedTruck
Lets say I run it to 1/8th and then go to 1/2 and back again and keep repeating?
Old 10-20-2013, 02:19 PM
Mine rarely gets above a half tank..... I have been running it that way since I bought it. (shortly before my join date....)
Old 10-20-2013, 02:20 PM
zman17's Avatar
zman17
zman17 is offline
The MMO will help the sending unit, not to mention it can be a benefit to the motor itself. (Fuel system)
Old 10-20-2013, 02:21 PM
TheBigRedTruck
ok. thanks guys
Quick Reply: Fuel level for fuel pump
