oil
Old 10-17-2013, 06:47 PM
tschay's Avatar
tschay
tschay is offline
Question oil
i have a 2000 neon the oil light goes on and off about 1min. intervals. about 1 week ago i disconnected the oil sending unit so when it came on i checked the oil it is not low it is in the safe zone so i kept driving home. so what do u think it is. i thought it might be its time to change the oil. i dont know what it could be???????? thanx, tschay
Old 10-18-2013, 03:59 AM
AnthemBassMan's Avatar
AnthemBassMan
AnthemBassMan is offline
-Just sounds like a bad sending unit to me. Or pull the old one out and see if there's a bunch of sludge buildup on it. Could also possibly be a bad wire connection at the sending unit...
L8R,
Matt
Old 10-19-2013, 02:33 PM
tschay's Avatar
tschay
tschay is offline
thats what i thought but the wire is off WEIRD
tschay
Old 10-19-2013, 04:00 PM
darthroush's Avatar
darthroush
darthroush is offline
Section Moderator
If you unplugged the sensor, I'd venture to guess that is why your light is on. There's no pressure reading, so the computer is saying there's a problem (light on).
Old 10-20-2013, 12:42 PM
AnthemBassMan
-And that should do it. Didn't realize you left it unplugged...
L8R,
Matt
Old 10-20-2013, 07:26 PM
darthroush's Avatar
darthroush
Section Moderator
I mean, you should still replace what sounds like a bad sender/sensor as AnthemBassMan said, and then plug the connector back in.
Old 10-21-2013, 07:14 PM
tschay's Avatar
tschay
tschay is offline
thanx guys i will. thanx again
