Front Heater Core
Old 10-14-2013, 09:44 AM
Fins59's Avatar
Fins59
Fins59 is offline
Default Front Heater Core
I have a 1998 Dodge Ram Van 1500 (full size but a shorty). 3.9 engine.
I need a new FRONT heater core, but just can't seem to find one. All listings I have seen list only the REAR.
Anybody know of a source for a new FRONT heater core?
Right now I have the heater core bypassed but winter is right around the corner here in WI.
Old 10-14-2013, 09:59 AM
blackvan's Avatar
blackvan
blackvan is offline
Old 10-14-2013, 09:24 PM
Fins59's Avatar
Fins59
Fins59 is offline
Thank you very much blackvan. Ordered the heater core. Will post results.
Old 12-09-2013, 08:01 PM
Fins59's Avatar
Fins59
Fins59 is offline
Follow up on my heater core. Finally received it Core arrived Nov 15, so it took about a month. It looks to be the correct core judging by the in and out tubes.
Problem right now is that I can't get at the old one. Having a hard time removing the heater box. Unhooked AC, removed a lot of fasteners but it still won't budge. Must be a hidden fastener somewhere holding it. I have a Haynes manual. In this case it seems a little difficult to decipher.
Old 12-09-2013, 08:13 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Did you remove the nuts from the firewall inside the cabin?
Also, there is a linkage rod that passes through the firewall. Make sure you tie a string to this linkage under the dash, so that the string gets pulled through the firewall as you remove the heater box. Using the string to pull the linkage back through the firewall during assembly will make your life much easier.
Old 12-09-2013, 09:10 PM
blackvan's Avatar
blackvan
blackvan is offline
Old 12-09-2013, 09:43 PM
blackvan's Avatar
blackvan
blackvan is offline
Old 12-10-2013, 06:55 AM
nibroc's Avatar
nibroc
nibroc is offline
doing a '92 3/4 ton van is just as bad
Old 12-10-2013, 11:02 AM
blackvan's Avatar
blackvan
blackvan is offline
Old 12-11-2013, 11:58 PM
Fins59's Avatar
Fins59
Fins59 is offline
Thanks for all the tips. I did remove the screws and nuts inside cabin under/behind the glove box. Lucky I get to drive the wife's car until I get er done. It's below zero here this week.
Back in the day I had a '80 Dodge shorty van B100 with the 225 six. I replaced heater core on that one and if I recall correctly there were about 10 hex screws holding down a cover. All the screws were easily accessible and once cover was off, heater core was right there, easy to remove and replace. That was one of my favorite vehicles but she rusted away.
Quick Reply: Front Heater Core
