Transmission Pan Sealant Thread
Old 10-13-2013, 11:41 AM
bigaaron's Avatar
bigaaron
bigaaron is offline
Default Transmission Pan Sealant Thread
I need to know what you guys use. I need a good transmission pan sealant. Seems like everyone i look at has some sort of one-off which always leaves me doubting its capabilities. I tried calling the trans shop and they use some sort of industrial use sealant that they can only procure - So what do you use?
Old 10-13-2013, 11:58 AM
kejobe's Avatar
kejobe
kejobe is offline
I've always used Ultra Copper from Permatex. Can be bought at any auto store.
Old 10-13-2013, 12:05 PM
HeyYou is online now
I just use a good quality gasket. The nice, rubber (viton?) re-useable fellers. No sealant at all.
Old 10-13-2013, 12:08 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is online now
Pickup MOPAR transmission pan gasket 2464324AC and install it without sealant. I never use any added sealer transmission pan gaskets.
Old 10-13-2013, 12:28 PM
mibzzer15's Avatar
mibzzer15
mibzzer15 is offline
I use like the cork "felpro" type gaskets all the time. When at work, we never use rubber gaskets unless that is our last option. In our experience, rubber gaskets tend to leak a lot more often than anything else.
Old 10-13-2013, 12:56 PM
Arde's Avatar
Arde
Arde is offline
Rubber gasket, no sealer, no leaks.
Old 10-13-2013, 01:57 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
felpro from advance. no sealant.
the filter/gasket kit from advance with the rubber gasket is also very good.
make sure the pan surface is flat. turn the pan upside down on the workbench and tap out any dimpled bolt holes with a ballpeen hammer.
Old 10-13-2013, 04:35 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
+1 on taping on the bolt holes to flatten the pan, and rubber wix gasket that comes with the filter or a felpro rubber gasket, or the mopar reusable gasket, FTW. Install new gasket , torgue to 13ft pounds and recheck torque a couple days later and at every engine oil change. Check VC bolts too at every oil change.
Old 10-13-2013, 04:38 PM
bigaaron's Avatar
bigaaron
bigaaron is offline
i tried all those options; rubber gaskets, sealant, no sealant, cork, EPDM, even special ordered a viton. I used the cross bolt pattern recommended by Hayes and Mopar. Checked and double checked torque spec, even had my torque wrench calibrated. New pan, old pan, checked all surfaces on a flat slab table - all leaked. Cleaned all surfaces by hand using red scotch pad, no sandpapers, power tool, pnuematic tools, or even hand tools - minus the gasket scrapper - all leaked.
Kejobe - i almost picked up the ultra copper per O'reilly's salesman - it states do not use on rubber gaskets. See what I mean? Hence the question. I guess I am retarded
Old 10-13-2013, 05:15 PM
zman17's Avatar
zman17
zman17 is offline
Something is obviously not right, because no sealant is required. But, a thin bead bead of regular old blue rtv should work fine. Are you sure the leak is coming from the pan itself? Somehow I dont think so.
Quick Reply: Transmission Pan Sealant Thread
