1999 dakota Front rotor removal
10-07-2013, 08:35 AM
on
I am having trouble getting the rotor off. Its a 4 wd does the rotor just come off after the caliper is removed? Or do I have to take the hub nut off. I am not sure what to do
10-07-2013, 09:37 AM
It just pulls off.
Smack it with a big hammer just make sure you don't hit the studs.
Depending on the rotor there may be a screw hole to push the rotor off though, I've never had to use that method.
Go with a BFH.
10-08-2013, 09:09 AM
on
One side on my truck is easy as heck to remove, the other side always requires the BFH. I still use a piece of wood to protect it, just in case the replacement is somehow bad.
Good luck!
10-08-2013, 10:01 AM
If never removed some have retaining clips on a stud or two look for them.
But a BFH is the answer
