white smoke on start up
Old 10-06-2013, 12:57 PM
Wes1997dodge's Avatar
Wes1997dodge
Wes1997dodge is offline
Default white smoke on start up
I got a 1997 dodge ram 1500 with a 5.9 its got 132,000 miles on it. Recently had to put two brand new heads on due to both of the old ones being cracked. I also put a high volume oil pump on and thoroughly cleaned the engine. Ever since I had that done it now smokes a little smoke when it starts up after sitting for a period of time longer than about an hour or so. The smoke looks white but smells like oil. What could be the problem?
Old 10-06-2013, 01:00 PM
While you had it apart, did you fix the plenum gasket on the bottom of the intake? Tends to suck oil thru there.
Old 10-06-2013, 01:02 PM
Wes1997dodge
Yes I put the Hughes plenum plate on
Old 10-06-2013, 01:10 PM
How long has it been doing this? Losing any oil/coolant? How long does the smoke last?
Old 10-06-2013, 01:59 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Leaky valves?
Old 10-06-2013, 06:20 PM
Wes1997dodge
Not loosing any coolant and it has been doin it for maybe a month and it only smokes for about 10-15 seconds after start up
Old 10-07-2013, 01:23 AM
Paul DeHayes's Avatar
Paul DeHayes
Paul DeHayes is offline
How are your driving habits? (ie short or long trips) If you short-trip the truck, I'd take it on a long highway trip (to eliminate excess moisture out of the exhaust system), waiting for a bit afterwards until it's completely cold again, and then crank her back up and see if you get the same results.
Old 10-07-2013, 10:26 AM
Probably just condensation in the exhaust.
Old 10-07-2013, 10:36 PM
Wes1997dodge
Smells like oil though
Old 10-07-2013, 11:03 PM
topkin's Avatar
topkin
topkin is offline
Is the smoke comming out of the tail pipe or from elsewear? You said you cleaned the engine, could it be things you used to clean just burning off the block and exhaust?
If its comming out of the tail pipe, are you checking the dip stick consistantly to see if you are gradualy loosing oil?
Quick Reply: white smoke on start up
