99 ram 1500 4x4 cam?
Old 10-01-2013, 07:09 PM
k5blazer35035's Avatar
k5blazer35035
k5blazer35035 is offline
Default 99 ram 1500 4x4 cam?
Hi, i have a 99 dodge ram 5.2 i am currently rebuilding.. i have a few question on what to get. first off what type of piston would be better a flat top or 4 valve release?? how big of a cam can i go? im looking for low end and mid range torque with a noticable idle if possiable.. the rebuild is going to be sock sizes.. just want a nice cam and im putting headers on it too. also gettin a hughes plenum repair kit .. for a cam i was looking at the Xtreme Energy XE256H: Cam & Kit.. would this work?? thanks
Old 10-01-2013, 08:43 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
as far as i know that cam will work just fine. but remember in order to get the full bang out of it, you will have to get it tuned for it.
Old 10-01-2013, 09:09 PM
moe7404's Avatar
moe7404
moe7404 is offline
if its a daily driver dont go over .430 lift, and 268 degrees advertised, not .050 and i think is close to the magum cam, just my idea.
Old 10-01-2013, 10:40 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is online now
That cam won't work, you have a roller cam not a flat tappet cam.
From Summit's website: http://www.summitracing.com/search/d...rder=Ascending
Old 10-03-2013, 11:05 AM
k5blazer35035
well i came up with is.. http://www.compcams.com/Company/CC/c...?csid=659&sb=2 i believe ima go with it
Old 10-03-2013, 11:07 AM
Make sure you pay attention to the note. Stock springs cannot be used.
Old 10-03-2013, 11:14 AM
k5blazer35035
Old 10-03-2013, 11:16 AM
Those would be overkill. Bind at .620? You are only doing .480 lift.... Something a little taller than stock is all you really need. I would have a chat with comp cams, and ask them what they recommend.
Old 10-03-2013, 11:19 AM
k5blazer35035
ooh lol well i did they jus said to contact mopar they can get you what u need
Old 10-03-2013, 11:41 AM
k5blazer35035
so these should be good then right? http://www.ebay.com/itm/COMP-318-360-CHRYLSER-1-494-SINGLE-VALVE-SPRINGS-SPRING-KIT-480-Max-Lift-MOPAR-/200963088654?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eca55610e&vxp=mtr
Quick Reply: 99 ram 1500 4x4 cam?
