Transmission Fluid/Filter change
Old 09-27-2013, 06:26 PM
Rkymtnh's Avatar
Rkymtnh
Rkymtnh is offline
Default Transmission Fluid/Filter change
I'll be changing the Transmission Fluid and Filter this weekend on my 05 Ram.
After the pan is off and all the fluid has Drained/Spilled out.
Is there a timetable to begin the refill ? or, is it more like,
After I've cleaned the mess up, I can then start to refill ?
Which brand to use ?
-- Castrol/Transmax ATF+4
-- Valvoline/ATF+4
-- Auto-zone ATF+4
Thanks
Old 09-27-2013, 06:31 PM
Rkymtnh's Avatar
Rkymtnh
Rkymtnh is offline
Also. Is adding a bottle of Lucas Trans Conditioner a good idea at this point ?
Trans has 139,000 miles on it. I towed a Jeep and trailer approx. 8 times a
year for the past two years up thru the mountains of Pennsylvania.
Old 09-27-2013, 09:17 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Mine probably drained for a couple or three hours while I cleaned the pan and applied a thin layer of RTV (mostly to hold the new gasket in place). I used seven quarts of Valvoline.
Old 09-28-2013, 02:26 AM
Prismatic's Avatar
Prismatic
Prismatic is offline
Do not add any transmission additives to the fluid.
Old 09-28-2013, 08:33 AM
Rkymtnh's Avatar
Rkymtnh
Rkymtnh is offline
Gotcha.That's a good idea. It does look like the gasket will need a little help staying in it's place. Thanks.
Ok. Not doubting you, just wondering if there's a reasoning for not adding any ? Thanks
Old 09-28-2013, 03:05 PM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
I take it you guys decided to add a gasket, or was this with an aftermarket pan? OEM uses RTV to seal the pan; my PML pan came with a gasket.
Old 09-28-2013, 03:25 PM
Rkymtnh's Avatar
Rkymtnh
Rkymtnh is offline
There were two different trans filter kits to get.
The one I bought, which said it was for the 15 bolt pan, came with a gasket.
The other one says to use RTV.
I also bought a tube of Black RTV, just in case.
Old 09-29-2013, 10:43 AM
catawissarocket's Avatar
catawissarocket
catawissarocket is offline
I'm assuming you went to auto zone? I saw the same, two different ones to choose from.I'm just doing drop and drain, no flush, so how many quarts will I need?
Old 09-29-2013, 10:46 AM
catawissarocket
Also should I get the one with the gasket or the other that u use rvt ?
Old 09-29-2013, 03:54 PM
Rkymtnh's Avatar
Rkymtnh
Rkymtnh is offline
Yes, Auto zone. Drop and drain also. No flush. Pretty sure OEM calls for 6.6 quarts. I went with Auto zone ATF-4 for Chrysler. It was either that or Valvaline ATF-4.
Quick Reply: Transmission Fluid/Filter change
