Which Dif is this ? Limited slip or Open - Pics
Old 09-26-2013, 06:06 PM
dixonmusic's Avatar
dixonmusic
dixonmusic is offline
Default Which Dif is this ? Limited slip or Open - Pics
I just got a 98 1500 5.2 Automatic 2WD Ext Cab, sticker under hood say's:
DMD 3.5 Axle ratio
DRB Rear Axle Chrysler 9.25
DSA Limited Slip Differential
Do i have Limited Slip Dif (LSD) that needs additive and 4.5 pints of oil OR Open that doesn't need additive and ? pints.
My Pics seem to say otherwise ?? or do they
Thanks for help.
DD in SC
2001 Dodge Dakota Quad Cab 3.9 Auto 2wd
1998 Dodge Ram 1500 Ext Cab 5.2 Auto 2wd
Old 09-26-2013, 06:14 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Looks open to me based upon the pictures. Perhaps, someone switched out the guts of the diff or the entire rear axle.
Old 09-26-2013, 08:18 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
its open.
see the side gears on each side with the axle shaft ends poking through.
and the cross pin from top to bottom
and all the open space between (no clutches or springs).
Old 09-26-2013, 08:23 PM
kejobe's Avatar
kejobe
kejobe is offline
As stated, open.
Old 09-26-2013, 08:51 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
Well I don't think its a open diff, the lsd clutch pack is behind the side gears and that is not clear in the pix he has posted.
Old 09-26-2013, 08:58 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
I would say to floor it on a dirt road, but if it is LSD, that's a great way to trash it if you don't have additive.
Then again, when in doubt, just add the additive. Still cheaper than a rear end rebuild if you screw up.
Old 09-26-2013, 09:21 PM
kejobe's Avatar
kejobe
kejobe is offline
I would say to floor it on a dirt road.
Doesn't mean anything. My BMW left two marks on concrete, but it has a open diff.
Easiest way to check is to lift the rear up and spin one tire by hand. If the other tire spins the same direction it's "posi", if it spins opposite, it's open.
Old 09-26-2013, 09:30 PM
merc225hp's Avatar
merc225hp
I had one over in the barn ready to ship so I opened it up to take some picks for the Op.
Op here are some picks you can use for reference.
Lsd disk pack behind the side gear.
Side view
Old 09-26-2013, 09:47 PM
stewie01's Avatar
stewie01
stewie01 is offline
Same my with open diff....
Old 09-26-2013, 09:57 PM
dodge dude94
I wouldn't know, as I don't have an open diff in my Ram. And the 76 makes too much damn power to only spin one wheel.
Quick Reply: Which Dif is this ? Limited slip or Open - Pics
