9.25 Gear install ?
Old 09-18-2013, 10:32 PM
getdown78's Avatar
getdown78
getdown78 is offline
Default 9.25 Gear install ?
I am about to install a set of 4.56s in my rear but what is the easiest way to turn the side adjusters ? Can you use a flat screwdriver ?
Old 09-19-2013, 11:34 AM
getdown78's Avatar
getdown78
Ok guys, I am gonna try to do this install tomarrow or saturday so i need some info on the easiest way to adjust the ring gear ? Please fill me in ?
Old 09-19-2013, 11:57 AM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
try the service manual, thats all i got haha
Old 09-19-2013, 12:59 PM
Yep, procedure is in the service manual, need some precision measuring tools though, if you don't have them, might be available to rent at your local parts store.
Old 09-19-2013, 01:07 PM
getdown78's Avatar
getdown78
I am gonna paint the ring gear and look at it to set it up ! I have never used measuring tools to set up any gear set i have ever done and had no problems but never done a dodge !
Old 09-19-2013, 01:11 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
The 9.25 is one of the ezest rear diff's to work on made just shy of the F 9".
Differential Case Installation
1.Apply a coating of hypoid gear lubricant to the differential bearings, bearing cups and the threaded adjusters. Carefully position the assembled differential case in the housing.
2 Observe the reference marks and install the differential bearing caps at their original locations
3 Install the bearing cap bolts. Tighten the upper bolts to 10 ft. lbs. (14 Nm). Tighten the lower bolts finger-tight until the bolt head is lightly seated.
Bearing Preload Torque and Ring Gear Backlash Adjustment
The following limitations must be considered when adjusting the differential bearing preload torque and ring gear backlash. The maximum permissible ring gear backlash variation is 0.003 in. (0.076mm). For example, if the minimum backlash is 0.006 in. (0.152mm) at one location, the maximum can be no more than 0.009 in. (0.229mm) at another location.
This variation represents the maximum permissible run-out and it is important to mark the gears so the same teeth are engaged (meshed) during all backlash measurements. It is also important to maintain the specified threaded-adjuster torque while adjusting the differential bearing preload torque and the ring gear backlash. Excessive adjuster torque will introduce a high bearing load and cause premature bearing failure. Insufficient adjuster torque can result in excessive differential case free-play and ring gear noise.
The differential bearing cups will not always immediately follow the threaded adjusters as they are moved during adjustment. Ensure accurate bearing cup responses to the adjustments. Maintain the gear teeth engaged (meshed) as marked. The bearings must be seated by rapidly rotating the pinion gear a half turn back and forth. Do this five to ten times each time the threaded adjusters are adjusted.
1. Use Wrench C-4164, or equivalent, to adjust each threaded adjuster inward until the differential bearing free-play is eliminated. Allow some ring gear backlash (approximately 0.01 in. or 0.25mm) between the ring and pinion gear. Seat the bearing cups with the procedure described previously.
2. Install Dial Indicator C-3339, or equivalent. Position the plunger against the drive side of a ring gear tooth. Measure the backlash at 4 positions around the perimeter of the ring gear (with an arc interval of approximately 90° between each position) to locate the area of minimum backlash.
3. Rotate the ring gear to the position of the least backlash (as indicated by the dial indicator pointer). Mark the gear so that all future backlash measurements will be taken with the same gear teeth meshed.
4. Loosen the right-side, tighten the left-side threaded adjuster. Obtain backlash of 0.003-0.004 (0.076-0.102mm) with each adjuster tightened to 10 ft. lbs. (14 Nm). Seat the bearing cups with the procedure described previously.
5 Tighten the differential bearing cap bolts. On 83/8 in. diameter to 70 ft. lbs. (95 Nm). On 91/4 in. diameter with 100 ft. lbs. (136 Nm).
6. Use Wrench C-4164, or equivalent, to tighten the right-side threaded adjuster to 75 ft. lbs. (102 Nm). Seat the bearing rollers as previously described. Continue to tighten the right-side adjuster and seat bearing rollers until the torque remains constant at 75 ft. lbs. (102 Nm).
7. Measure the ring gear backlash. If the backlash is not 0.006-0.008 in. (0.15-0.20 mm), continue increasing the torque at the right-side adjuster until obtained. Continue increasing the torque at the right-side threaded adjuster (seat the bearing cups with the procedure described above) until the specified backlash is obtained.
If all the instructions have been correctly completed, the left-side threaded adjuster should be approximately 75 ft. lbs. (102 Nm). If the torque is substantially less, the complete procedure must be completed.
1. Tighten the left-side threaded adjuster until 75 ft. lbs. (102 Nm) is indicated. Seat the bearing rollers with the procedure previously described. Do this until the torque remains constant.
2. After the adjustments are completed, install the threaded adjuster locks. On 91/4 in. diameter, the lock teeth are engaged with the the adjuster threads. On 83/8 in. diameter, the lock finger is engaged with an adjuster hole. Tighten the lock screws to 90 inch lbs. (10 Nm).
Old 09-19-2013, 09:04 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Wildman4x4nut is offline
How do you check for .006 backlash with paint? I doubt your eyes and hands are calibrated to that degree. At this point you've been lucky as heck. Do you know why there is a need for backlash and what happens if it is too tight or too loose? By not setting the backlash you run the chance of ruining the gears.
Old 09-19-2013, 09:17 PM
Arde's Avatar
Arde
Arde is offline
Right...and not to mention pinion bearing and carrier bearing preload. I'll stick with the measuring tools myself.
Old 09-19-2013, 10:54 PM
getdown78's Avatar
getdown78
I learned by feel and thats the way i will do it ! I can't afford hundreds of $ to buy measuring tools that i might use twice a yr !
Old 09-19-2013, 11:02 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Well, don't come back in b1tching and complaining when your brand new gears are whining. That's all we're saying.
Quick Reply: 9.25 Gear install ?
