Towing and tire size
Old 09-16-2013, 03:02 PM
goldnsands1's Avatar
goldnsands1
goldnsands1 is offline
Default Towing and tire size
I'm towing a 32' 5700 lb. travel trailer. My '96 1500 Ram 5.9 4x4 has a 4" lift with Toyo 315/75/R16 tires. I have a EZ lift elite round bar weight-distributing hitch system with 1 stabilizer. The handling and power are lacking. What tire size do you recommend I reduce to for better handling?
Old 09-16-2013, 04:33 PM
SilverSS's Avatar
SilverSS
SilverSS is offline
What gears do you have? Probably close to stock size would be best. The smaller tire changes your gear ratio and will give you better acceleration.
Old 09-16-2013, 06:40 PM
Given the prices of tires lately..... I would be more tempted to re-gear, if your tires are still in good shape. Cost is slightly more, but, stock size tires, with a lift, are gonna look funny.....
Just be REAL sure to leave O/D off when towing.
Old 09-16-2013, 06:42 PM
BBartow's Avatar
BBartow
BBartow is offline
This is true.
kejobe's Avatar
kejobe
kejobe is offline
Unfortunately, with the lift it won't look right if you go with smaller tires. Re-gearing is the best option, but then, it is more than the cost of tires.
Old 09-16-2013, 06:47 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
+1... 315's are way to big for 3:55 gears.
Old 09-16-2013, 06:56 PM
or even 4:10s when trying to tow 5K plus pounds....
Old 09-16-2013, 06:58 PM
zman17's Avatar
zman17
zman17 is offline
Those tires are too big even without towing for 3:55's.
Old 09-16-2013, 07:19 PM
BBartow's Avatar
BBartow
BBartow is offline
Toyo's are especially heavy. I would just regear to 4.56s and leave the tires.
Old 09-16-2013, 07:39 PM
getdown78's Avatar
getdown78
getdown78 is offline
Even if he regears what kind of mpg should he get pulling that camper ?
Quick Reply: Towing and tire size
