Timing Chain
Old 09-16-2013, 12:26 PM
TheBigRedTruck's Avatar
TheBigRedTruck
TheBigRedTruck is offline
Default Timing Chain
I'll be doing my timing chain soon and just wondering why the distributor cap needs to be removed to do this?
Old 09-16-2013, 12:28 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
It doesn't. Pull off the old timing set, line up the new one where the marks were on the old one, install.
Old 09-16-2013, 12:31 PM
Arde's Avatar
Arde
Arde is offline
It doesn't. Easiest way is to pull timing cover off, turn engine over with a socket till cam timing mark is at 6 o clock and cam timing mark is at 12 o clock. Pull off the old, put on the new.
Old 09-16-2013, 12:36 PM
TheBigRedTruck
That's what I thought because the book said otherwise. Do I need a tool to remove the gears off the cam and crank
Old 09-16-2013, 12:40 PM
Arde's Avatar
Arde
Arde is offline
No, they're just a slip fit. May have to pry a little.
Old 09-16-2013, 12:42 PM
Arde's Avatar
Arde
Arde is offline
Mine were easy, there's a possibility you may need a puller.
Old 09-16-2013, 12:48 PM
TheBigRedTruck
awesome, I know I need the harmonic balancer puller, certain type that doesn't grab the outside of it
Old 09-16-2013, 12:53 PM
stewie01's Avatar
stewie01
stewie01 is offline
It's either got threaded holes for bolts and nuts or you'll need a 3 jaw puller...
Arde's Avatar
Arde
Arde is offline
I used two of the long bolts from the water pump with my puller to get the harmonic balancer off, but don't think i needed a puller to get the timing gears off IIRC.
Old 09-16-2013, 12:54 PM
TheBigRedTruck
sounds easy to do. I can take apart everything up to the clutch fan in 10 minutes, the rest should be easy
Quick Reply: Timing Chain
