08 Ram 2500 Cummins manual trans question?
Old 09-10-2013, 10:51 PM
dan983's Avatar
dan983
dan983 is offline
Angry 08 Ram 2500 Cummins manual trans question?
Hello: I'd appreciate any thoughts concerning my G-56 manual transmission! I have an 08 Ram 2500 4x4 with 110k miles. Recently I had to replace the clutch and in doing so, added a quart of ATF 4 through the hump. The fluid was replaced by the dealer at 60K miles.
Recently, while stopped I've noticed going into 1st or second gear is very difficult unless I first go into 3rd gear prior to starting out in 1st or 2nd? Pumping the clutch doesn't help so I know the clutch is functional. Also, I noticed a gear growl when slowly backing up in reverse moving my boat?
Thanks in advance!
Dan
Quick Reply: 08 Ram 2500 Cummins manual trans question?
