2000 4.7 losing oil and coolant
Old 09-06-2013, 06:41 PM
bigred95's Avatar
bigred95
bigred95 is offline
Default 2000 4.7 losing oil and coolant
just me again guys. i was going through and checking everything and noticed my coolant and oil are basically gone. not burning anything that i can see or smell. oil isn't milky and coolant isn't brown. I'm really confused here guys. Thanks for the help, love the dodgeforum, a lot of knowledgeable people on here
Old 09-06-2013, 07:22 PM
that_guy's Avatar
that_guy
that_guy is offline
I'd put more coolant and oil in and watch for any leaks. Put a clean piece of cardboard underneath it.
Old 09-07-2013, 10:59 AM
bigred95's Avatar
bigred95
bigred95 is offline
tried it last night, nothing on the cardboard.
Old 09-07-2013, 12:17 PM
that_guy's Avatar
that_guy
that_guy is offline
Did the levels go down any over night? You might want to try running it and watching for any drips underneath too.
Old 09-07-2013, 02:12 PM
bigred95's Avatar
bigred95
bigred95 is offline
Nope not overnight. It's gradual. The oil took about 2800 miles and the coolant was put in 1000 miles ago
Old 09-07-2013, 02:26 PM
topdogcustoms's Avatar
topdogcustoms
topdogcustoms is offline
what engine do you have
Old 09-07-2013, 02:33 PM
that_guy's Avatar
that_guy
that_guy is offline
How much has the oil gone down. Eventually the engine is going to burn some oil. My 5.2 with 160,000miles burns a quart every 2000 miles, which is'nt unusual for an engine with that mileage. Not sure about the coolant though, my level doesn't change.
Well the title says 2000 4.7
Old 09-07-2013, 03:02 PM
bigred95's Avatar
bigred95
bigred95 is offline
i lost about 3 quarts over 3000 miles, it barely showed on the dip stick, and i believe that shows about 3 quarts. the thing is it doesn't smoke. i noticed around the front crank seal and around the oil pan there is some oil around there, so possibly the gaskets are bad there, or the pcv valve is bad, although i checked it and it still rattled. It's possible the oil leaks and blows off while i'm driving, but i don't see any oil on the underbody to indicate that it's blowing off and it doesn't drip after driving
Old 09-08-2013, 01:24 AM
RockGuardedDak's Avatar
RockGuardedDak
RockGuardedDak is offline
Check around the valve covers. Mine leaks from the valve covers despite new gaskets... Every 4.7 I've come across has leaked from the valve covers
Old 09-08-2013, 10:56 AM
bigred95's Avatar
bigred95
bigred95 is offline
i believe it's not leaking from the valve covers but i'll give it another look. the losing antifreeze is still really confusing
Quick Reply: 2000 4.7 losing oil and coolant
