1999 Dodge 2500 steering box adjustment
Old 09-06-2013, 05:42 PM
amili01's Avatar
amili01
amili01 is offline
Default 1999 Dodge 2500 steering box adjustment
can someone help me with the procedure to adjust the steering box on a 1999 Dodge Ram 4x4 Diesel? Truck is wandering when driving down the road.
thank you.
Old 09-06-2013, 06:29 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
The procedure should be in the factory service manual, which is available for download on this site. The procedure I used to adjust the box is to loosen the locknut on top of the steering box. Use an allen wrench to lightly tighten the center nut just enough to feel some resistance from the adjuster screw. Once adjusted, hold the adjuster screw in place with the allen wrench and tighten the locknut. Test drive the truck and see if it better. Please note that the slop may be coming from the steering column, too.. Also, the factory steering boxes have a tendancy to just wear out over time. If you find the slop won't adjust away to your liking, then best to think about purchasing a new steering gearbox from either Borgeson or Redhead.
Old 09-06-2013, 06:40 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Before adjusting the steering box make sure everything that connects the steering wheel to the wheels is in good shape; steering column has no play, pitman arm undamaged, drag link and tierod and TRE's have no play, etc.
Old 09-06-2013, 07:05 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Here is the procedure, but, you are wasting your time without a couple special tools. Get a Red-Head steering box, done.
http://dodgeram.org/tech/mods/steeri...ear/Adjust.htm
Quick Reply: 1999 Dodge 2500 steering box adjustment
