97 neon crank sensor wiring
Old 08-27-2013, 11:31 AM
DodgeGuy12's Avatar
DodgeGuy12
DodgeGuy12 is offline
Default 97 neon crank sensor wiring
Where do the wires go from the crank sensor?
I think i need to run new ones.
I have traced the bucking/dying to a bad pigtail for the sensor, but since I have replaced the pigtail, I have experienced hesitation from a start and backfiring through the intake. I think I may need to replace all of the wiring.
I have checked the timing, it is correct, and I have replaced the CPS as well with one from a junkyard, and the car just went haywire, so I put the original back in. I did these changes with the battery disconnected.
Old 09-14-2013, 04:20 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
Are you sure the cps is the problem?
Quick Reply: 97 neon crank sensor wiring
