Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Dodge intrepid no start problem
Old 08-03-2013, 01:50 PM
C-white4585's Avatar
C-white4585
C-white4585 is offline
Default Dodge intrepid no start problem
Ok guys i really need some help here. I have an '03 dodge intrepid 2.7 that won't start. It cranks, has spark, combustion and is getting fuel. I have had some recent problems where the car stalled out and wouldn't start and was able to get it going by unplugging and reconnecting the iac. Tried that didn't work, took the whole valve out tried to start it nothing. Cleaned the iac valve and throttle assembly. took out the cps and tried to start it(read somewhere that if it was bad i would be atleast able to start it in limp mode like that) but nothing. It is not throwing any codes and I have no ideas left, if anyone can help it would be greatly appreciated.
Old 09-20-2013, 08:46 PM
earlward's Avatar
earlward
earlward is offline
Mine was a camshaft position sensor. Cheap fix easy to replace.
Quick Reply: Dodge intrepid no start problem
