BLOWER MOTOR ONLY WORKS ON HIGH
Old 09-28-2005, 04:35 PM
EKOSMUS's Avatar
EKOSMUS
EKOSMUS is offline
Default BLOWER MOTOR ONLY WORKS ON HIGH
I have a 2002 dodge ram 1500 truck. The blower motor works on high but on no other setting. Could this be a blower motor resistor gone bad? If so where is it located?
Thanks,
Eric
Old 09-28-2005, 07:14 PM
Daksport1pa's Avatar
Daksport1pa
Daksport1pa is offline
Default RE: BLOWER MOTOR ONLY WORKS ON HIGH
Yea it is the blower motor resistor. The same thing happened to my 01 Dakota. I don't know where its located but if your truck is still under warranty you could take it back to the dealership and they'll take care of it for you.
Old 10-01-2005, 03:25 AM
ramfan5.9's Avatar
ramfan5.9
ramfan5.9 is offline
moving this to ram section so it gets more hits
welcome to DF btw
Old 10-01-2005, 03:44 AM
Natedogg625's Avatar
Natedogg625
Natedogg625 is offline
yea its the resistor, I have the same problem w/ my truck. already had it replaced once. Sucks to only have High!!!!!
Old 10-01-2005, 01:52 PM
05_black_beast's Avatar
05_black_beast
05_black_beast is offline
Sounds like the resistor to me as well. You can use a test lamp to check it. Just have someone there to move the selector in the cab, and probe the individual speed circuits. A different one should become hot for each speed. Voltage will also be varied.
Edit - It is located, and accessible on the bottom of the HVAC unit on the assenger side of the vehicle.
-jimmy
Old 10-01-2005, 03:04 PM
hemiyellow's Avatar
hemiyellow
hemiyellow is offline
DC Insider
i wouldnt worry awhole lot with testing it, i mean it dont cost but like $15, and it's prolly 99% gurantee that it the blowermotors resistor, i replaced alot of these workin at the dealership, but never one on a 3rd gen ram
Old 10-03-2005, 07:37 PM
Natedogg625
Just had my resistor replaced today, mine is still under warranty.
Old 10-04-2005, 12:22 PM
bign1976's Avatar
bign1976
bign1976 is offline
Same thing happened on my 03 Durango
Old 10-05-2005, 12:46 AM
mill500's Avatar
mill500
mill500 is offline
Just had this happen on my Wrangler....good to know. I would have started with the switch.
Old 10-05-2005, 02:22 AM
DonG's Avatar
DonG
DonG is offline
This is too common of a problem with DC vehicles. I wonder if they use the same part on most models. I changed mine for the same symptoms.
Quick Reply: BLOWER MOTOR ONLY WORKS ON HIGH
