CAD actuation
Old 07-30-2013, 05:41 PM
aofarrell2's Avatar
aofarrell2
aofarrell2 is offline
Default CAD actuation
It's the 1996 Dodge Ram in my signature.
I love being able to run the transfer case 2WD in lo range, but despise having to get out, pop the hood, and swap vacuum lines all over the place to get my CAD to engage/disengage, so I started looking around for a better solution.
I looked at PosiLok, and while that was great, I want to be able to control the CAD unit with a switch, not a lever or cable. Essentially, I came down to two ways: 1) Use 2 vacuum solenoids on the vacuum lines and reuse the stock CAD unit or 2) Put a spring on the inside of the CAD unit to hold it in disengage position, then use a 12VDC solenoid to engage it.
What are your thoughts?
Old 07-30-2013, 06:46 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Never mind.
Old 07-30-2013, 07:20 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Just get the damn posilock techjockey.
You like over complicating things.
Old 07-30-2013, 07:22 PM
aofarrell2's Avatar
aofarrell2
I like to make things easy for the operator. When the ladies start driving it or my dad, they have no clue how to actuate a posilock nor do they want to anyways - they are fine pulling the transfer case lever then flipping a switch though. It would look nicer as well too.
Old 07-30-2013, 07:23 PM
dodge dude94
Have you even seen the posilock? lmao
Old 07-30-2013, 07:42 PM
aofarrell2's Avatar
aofarrell2
Yes I have.
Old 07-30-2013, 08:22 PM
dodge dude94
Then you know that is is positively awesome and utterly reliable.
Old 07-30-2013, 08:40 PM
aofarrell2's Avatar
aofarrell2
I didn't say it wasn't awesome or wasn't reliable, I said I don't want manual engagement, I want to be able to flip a switch. Couldn't be any worse than the stock setup, in my experience the only complaint I have about the vacuum CAD is the time it takes to engage or disengage.
Old 07-30-2013, 08:42 PM
dodge dude94
To me, having to flip a switch IS manual engagement as the CAD AUTOMATICALLY engages when the t-case is in 4WD. lol
Old 07-30-2013, 09:14 PM
aofarrell2's Avatar
aofarrell2
Do you ever read my posts thoroughly? If you did you would see WHY i need it to be able to flip a switch to engage the CAD. Dumbo... Read what I said:
I like being able to put my tcase in 4lo but not have the front axle engaged, essentially 2lo, that's why I want a switch, so that it is NOT actuated by the tcase system, like it is from the factory.... Get it now?
Quick Reply: CAD actuation
