2010 Dodge Journey Fuel filter
The fuel filter assembly is mounted to the cowl near the brake booster.
1.Disconnect negative battery cable.
2.Remove air cleaner housing.
3.Disconnect fuel supply line (3) form fuel tank.
4.Disconnect fuel supply line to fuel pump (2).
5.Disconnect both fuel return lines (1,4) from the filter.
6.Remove filter retaining screw (5).
7.Remove filter from retaining bracket.
Walterleonardo (02-02-2023)
