ground problems after bed re-install..
Old 07-27-2013, 01:56 PM
redneck_ram's Avatar
redneck_ram
redneck_ram is offline
Default ground problems after bed re-install..
seems as though i may have a ground problem...
now that the truck is back together, anytime i hit the brakes, or turn signal, the back up light comes on.
this only happens when the trail harness is connected. when i by pass the trailer harness it doesnt do this. ive re-grounded the trailer harness, and it still hasnt fixed it.
any ideas?
anyone have a pic of the underside of their truck that has the tow package, so i can make sure im not connecting things wrong?
Old 07-27-2013, 02:01 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Yea, I have an idea. Don't remove the bed to do the fuel pump. I knew this was going to happen and be your next post. Be here next Saturday and we can look at mine and see where the grounds are.
Old 07-27-2013, 02:11 PM
redneck_ram
there are only 2 grounds. one at the front of the bed that connects to the cab, then the trailer wiring harness ground.
if i leave the trailer harness disconnected and just plug the main harness into the lights, everything works as it should.
the second i plug in the trailer harness it starts acting up.
as i stated i regrounded the trailer harness, but its still doing it.
Old 07-27-2013, 02:24 PM
zman17's Avatar
zman17
zman17 is offline
So everything works without the trailer hooked up?
Old 07-27-2013, 02:33 PM
redneck_ram
no trailer... its the factory 7 way harness that connects to the factory harness. its the vehicle side trailer harness thats acting up. i havent hooked up a trailer in months.
Old 07-27-2013, 03:12 PM
Then check your trailer harness for pinched wires, etc. Didn't set the bed down, and pinch it somewhere did you?
Old 07-27-2013, 04:49 PM
redneck_ram
nope no pinched wires... as you can see
however. i clipped the 12v wire, and brake feed wire, and pulled the harness out. i dont have a pic, but lets just say, i think i found my problem.
holy f'n corroded!
im going to call the dealer on monday to see about getting a new harness. if not, its either ebay, or a junk yard i guess.
Old 07-27-2013, 07:21 PM
redneck_ram
here are the corroded wires...
found the part number for the harness, so im going to go to the dealer, and order it. gonna be a 100ish dollar blow to the pocket.
Old 07-27-2013, 07:42 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
just resplice yours ??
Old 07-27-2013, 08:37 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Worth a shot
Quick Reply: ground problems after bed re-install..
