Lift on a 96 4x2
Old 07-27-2013, 08:57 AM
angelo's Avatar
angelo
angelo is offline
Default Lift on a 96 4x2
Installing a 2.5 inch spacer on the front and 3 inch blocks on the back of my 96 ram 2500. Wanted to know if I would have to put new shocks on the front and back and if I do what part numbers am I looking for. Went to the local part store and they don't have that info. Would I also have to modify any front end components?
Old 07-27-2013, 11:18 AM
Arde's Avatar
Arde
Arde is offline
I think you're good with stock shocks with up to a 3" lift, beyond that, you need to change shocks. Don't need to change anything in the front end with the 2.5" spacer.
Old 07-27-2013, 12:43 PM
angelo's Avatar
angelo
angelo is offline
I'm needing to change shocks on the back anyway and I carry a trailer all the time so if I wanted to put a longer shock so it never bottoms out what would I go with. Could I use the 4x4 shocks? Are they longer
Old 07-27-2013, 02:07 PM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
if your always pulling a load then I would get a set of Monroe tracloads. they are a coilover design that is not only slightly longer than stock but will bump your payload capacity up some. they do ride stiff without a load though.
as far as the spacers go, I tried that route on my 2500 2wd and had issues. I ended up removing them and now they're being used as door stops. I hope you don't have the same issues. I lost about 20% of my steering angle andmy steering knuckle was hitting the control arm before full lock.
Old 07-27-2013, 03:31 PM
Not sure that rear blocks are a good plan on a truck that tows regularly either, especially a 3/4 ton.... the blocks are already 5 inches, adding another three is going to give the axle a LOT of leverage on the springs......
Old 07-27-2013, 10:31 PM
dman12323's Avatar
dman12323
dman12323 is offline
+1 to and add-a-leaf?
Old 07-27-2013, 10:40 PM
angelo's Avatar
angelo
angelo is offline
The towing that I do is just lawn mowing so its not that much of a load but on the Monroe shocks what size or how would I know what to purchase? Do u by any chance have a part number
Old 07-27-2013, 10:44 PM
angelo's Avatar
angelo
angelo is offline
Why do u say already 5 inches. My truck does not have any blocks on it right now. All I would be doing is adding 3 inches
Old 07-28-2013, 09:21 AM
It doesn't? Pics please.
Old 07-28-2013, 10:06 AM
angelo's Avatar
angelo
angelo is offline
Mine is a 4x2 its not a 4x4. I'm assuming the 4x4 came with blocks
Quick Reply: Lift on a 96 4x2
