ABS light and code C1095
Old 07-26-2013, 08:42 AM
dbilik's Avatar
dbilik
dbilik is offline
Default ABS light and code C1095
I have an ABS code reader, getting C1095 code in a 2001 QC. I know that is listed as "ABS Hydaulic Pump Motor Circuit Failure". I don't have front wheel ABS, I know that. In fact, I don't think I have ABS at all. Anyone know what this code means I should checking?
Old 07-26-2013, 09:15 AM
Robbadodge's Avatar
Robbadodge
Robbadodge is offline
Pretty sure you have rear ABS, as I do (rear only). Contact Dodge here and ask for a build sheet. Have the last 8 of your VIN available, their list of factory hardware will confirm how your truck left the lot.
Check the ABS fuse, first. You may also have a broken wire going to the sensor(s). It's not a lot of help, but it gets you started.
Good luck!
Edit: Seeing so many different ABS codes in research, I realize the solution is not likely the fuse. I'm not well enough versed in the brakes to help. Others with much more experience will chime in before too long.
Old 07-26-2013, 10:57 AM
BlackTrim211's Avatar
BlackTrim211
BlackTrim211 is offline
i'm going to assume that it's a short or a broken wire, i'd simply start tracing wires from brake component to the end of the line.
Old 07-27-2013, 12:31 AM
dbilik's Avatar
dbilik
dbilik is offline
Wire makes sense. I would have never known that code would do that. But it did happen a little while after my Dad worked on the rear brakes, and if it is rear ABS this makes sense. Going to guess something got moved. I'll check it out and report back.
Quick Reply: ABS light and code C1095
