2011 avenger A/C help!
Old 07-18-2013, 02:38 AM
luvmidodge's Avatar
luvmidodge
luvmidodge is offline
Default 2011 avenger A/C help!
I really need help. I have a 2011 avenger I bought in January used. It now has 43K miles on it and is outside the warranty. Last week my AC went out and is making a weird tapping sound. Pepboys did a free A/C check and said my compressor is not engaging. But I don't think they checked very hard. It sounds like something is loose and is tapping. Sometimes it is louder than others. Any thoughts before I go shelling our the big bucks
Old 07-18-2013, 10:36 AM
1ATony's Avatar
1ATony
1ATony is offline
Former Vendor
If you turn the AC on you should be able to see if the AC clutch turns off and on. Did they check the Freon level too. Did they test the system for leaks at all?
Old 08-06-2013, 08:50 PM
tonyred9's Avatar
tonyred9
tonyred9 is offline
hey Tony, the compressor on these models are(or look like) they are always engaged.there is an electric valve switch on the back of the compressor that when engaged send the freon into action. i took one apart and cleaned the "reed" valves. if your is making noise it's probley the pump. and they are pricey$$$ and do NOT run this system under vacuum!!!
Quick Reply: 2011 avenger A/C help!
