Abs
Old 07-15-2013, 05:06 PM
dterry57's Avatar
dterry57
dterry57 is offline
Default Abs
05 Dodge 3500 Ram Cumins Diesel Cleaned battery cables now brake pedal goes to the floor. Not sure batteries and brake pedal is connected. Brakes don't work any suggestions. Also shows codes P2509 and P1755.
Old 07-16-2013, 10:16 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Go check your brake fluid level, turn get under the truck and inspect your brake lines physically. If those are good, then bleed your brake lines and use DOT 3 or 4 fluid
