Rubber stem for TPMS?
Old 06-29-2013, 05:40 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
Default Rubber stem for TPMS?
I remember someone claiming that they had a shop replace the aluminum stems with rubber ones that worked with the TPMS. Anyone have a brand or a link? Damn things are really ticking me off, 4th one broke today and at $40 a pop to get the tire demounted, new stem and nut it is getting a bit old.
Some safety feature, in 25 years of driving I've never had a valve stem go bad until I got the aluminum crap that they used on this truck.
09 ram with 17's
Old 06-30-2013, 07:09 AM
stealthgoat's Avatar
stealthgoat
stealthgoat is offline
I found them at Farm & Fleet.
Old 06-30-2013, 09:36 AM
LU229's Avatar
LU229
LU229 is offline
If your dealership is replacing them with the old metal style, they need to catch up with the times.... my local dealer is replacing the old ones with the newer OEM rubber stemmed style and no problems since.
Old 06-30-2013, 09:51 AM
oldjeep's Avatar
oldjeep
oldjeep is offline
I've been having them done at the local tire shop, guess I'll have to make a trip in to the dealer.
Old 06-30-2013, 04:10 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
Looks like they must be replacing the entire TPMS with the 2010 and up version.
Old 06-30-2013, 04:28 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
FYI:
http://www.ebay.com/itm/4-NEW-OEM-CHRYSLER-DODGE-JEEP-TPMS-56029398AB-433MHZ-TIRE-PRESSURE-SENSORS/151068791185?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D8729634011461647220%26pid%3D100011%26prg%3D1005%26rk%3D5%26sd%3D290785598227%26
Just bought a set of 4 for $68
Unfortunately now I need to decide if I'm going to chance 400 miles of towing with no spare or get the one bad stem replace in the next couple days and then replace them all when I get new tires.
Old 06-30-2013, 06:24 PM
Pedro Dog's Avatar
Pedro Dog
Pedro Dog is offline
Did you check for compatibility? The link on your post says they won't work on a 2009 Ram 1500 SLT. I'm sure you did but just cheking, or are you just using the stems?
Old 06-30-2013, 06:27 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
They are 433 MHZ just like the stock ones on an 09 and doing some checking around, 2010 stems are what they have been retrofitting onto 2009 rams.
Can't use just the stems since they attach in a different way to the sensor than the 09 which is a through fit rather than screw in.
Did the hi-lift trick and pulled the sensor out of my tire, so for the short term I'll just pick up one more metal stem kit and fix it until I'm back from vacation and ready to buy the new tires
Old 06-30-2013, 08:07 PM
Pedro Dog's Avatar
Pedro Dog
Hope they work out for you, I'm not saying they won't but the 2009-2010 P/N is 56029359AB for the aluminum stems. The rubber equivalents are 56029398AA for the 2010. You ordered P/N 56029398AB, so I don't know the difference between the AA and AB. They're all 433 MHz.
Old 06-30-2013, 08:15 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
3 different part numbers for the same thing:
Stock Code56029398AB ; 56029398AA; 68142397AA ManufacturerChryslerCategoriesElectrical > SENSORS; Wheels > Tire Monitoring System; Wheels > Wheels, Tires and Hardware
Quick Reply: Rubber stem for TPMS?
