Noise from either bellhousing or oil pan.
Old 06-26-2013, 04:31 AM
tbone360's Avatar
tbone360
tbone360 is offline
Default Noise from either bellhousing or oil pan.
Ok guys here's the problem. I'm getting this noise that sounds like something jumping around in the oil pan then it stops. Then sometimes it sounds like a clicking in the bellhousing. Any ideas? Let me know if more info is needed. Thanks in advance.
Old 06-26-2013, 07:53 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Remove the dust cover on the front of the transmission and see if one of the flex plate bolts has come loose and is bouncing around in the transmission bellhousing - also, might use an inspection mirror to look at the flex plate itself for cracks
Old 06-26-2013, 08:38 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
I have plenty of ideas.
Hope that helps.
Old 06-26-2013, 09:10 AM
tbone360's Avatar
tbone360
tbone360 is offline
Thanks I'll check it out when I get home.
Old 06-26-2013, 09:14 AM
tbone360's Avatar
tbone360
tbone360 is offline
Hope that helps.
Sure does. Thanks. Lol
Old 06-26-2013, 01:18 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by vwanddodge
i have plenty of ideas.
Hope that helps.
hahaha!
Quick Reply: Noise from either bellhousing or oil pan.
