Rear end failing. Again....
Old 06-23-2013, 08:32 PM
Cmerritt84's Avatar
Cmerritt84
Cmerritt84 is offline
Default Rear end failing. Again....
My rear end is howling on decel. Dope is full, no play in shaft. Amy idea what is going wrong??
This is not the first rear diff issue I've had.
Old 06-23-2013, 09:03 PM
oldjeep's Avatar
oldjeep
oldjeep is offline
Howling on deceleration usually means a bad outer pinion bearing. You said again - what was done to fix it the first time?
Old 06-23-2013, 09:10 PM
Cmerritt84's Avatar
Cmerritt84
It's failed 3 other times.
1st fail was pinion nut back off
2nd fail was carrier bearings, new gears, bearings
3rd fail was pinion nut again, complete new axle
Old 06-24-2013, 01:06 PM
Atomic Dog's Avatar
Atomic Dog
Atomic Dog is offline
Ugh. That totally sucks.
Old 06-25-2013, 01:00 AM
LVRR's Avatar
LVRR
LVRR is offline
Sounds like the tech's that worked on it didn't do a proper job or didn't know what they were doing. First time should have taken care of the problem, period.
Quick Reply: Rear end failing. Again....
