1500 haul limit
Old 06-23-2013, 05:11 PM
smoky614's Avatar
smoky614
smoky614 is offline
Default 1500 haul limit
Alright, i got a 1500 4x4 and im about to go get some mulch. If I fill my truck up itll be around 1600lbs. I know thats way too much for my 1/4 ton but i was thinkin bout half(800lbs). Still over a 1/4 ton but i dont think itll be a problem. I know Ive had just under a ton in my old 82 1/4ton ram prospector and barley made the bed sink(thing was a champ!!). But just out of curiosity, how much have yall hauled in your bed without breaking something?
Old 06-23-2013, 05:36 PM
Received 3,169 Likes on 2,923 Posts
5000 pounds of dirt in my 3/4 ton..... that definitely made 'er squat. I didn't have to go far though.
Old 06-23-2013, 05:46 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Mulch stacked above the cab while towing a stump grinder. Several scoops of gravel. Dirt, horse manure. A whole lot.
My springs sag a little now
Old 06-23-2013, 05:49 PM
kejobe's Avatar
kejobe
kejobe is offline
For an '01 but should be close enough.
http://dodgeram.info/2001/towing-charts.html
BTW, I've had about 3000 pounds in my little 1500.
Old 06-23-2013, 06:23 PM
Spillage's Avatar
Spillage
Spillage is offline
Passenger seat to the roof (boxes), tray to the roof line (furnature & boxes), and a tandem car trailer with a Neon (also packed to the gills)... PA to FL, not a problem.
Weight, no idea, but not light
Old 06-23-2013, 07:32 PM
moe7404's Avatar
moe7404
moe7404 is offline
dont for get to add air to the tires. stop by a good tire shop to find out how much air to add. dont use roads that will have the highway patrol on. they like to wright over weight trucks up.
Old 06-23-2013, 08:29 PM
Arde's Avatar
Arde
Arde is offline
Should be a 1/2 ton, right? 1600 lbs. is heavy, but you can probably get by if you stay out of OD and take it easy. I know mine has been that heavy. I just watch the springs when loading and quit when they start flexing the wrong way.
Old 06-23-2013, 08:30 PM
stewie01's Avatar
stewie01
stewie01 is offline
Old 06-23-2013, 08:48 PM
Ham Bone's Avatar
Ham Bone
Ham Bone is offline
Might wanna see if you have any bump stops. It should bottom out eventually
Old 06-23-2013, 09:01 PM
Arde's Avatar
Arde
Arde is offline
Yeah OK. I don't make a habit of it, but have loaded it that heavy a few times.
Quick Reply: 1500 haul limit
