Missing O2 Sensor Connector - Chasing it down
Old 06-23-2013, 01:07 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
Default Missing O2 Sensor Connector - Chasing it down
Hey all, got a rather strange issue. A bit ago some of you may remember I posted in another thread I was missing my front o2 sensor connector. Well I was gonna leave it til my mechanic could look at it, but I need to be able to run it while it sits and I dont want to kill my new cat already. I dont mean the o2 sensor itself, its there. I Mean the connector it plugs into! Ive searched high and low but cant find the thing anywhere. Its not there. Talking to my buddy who helped me put my high flow cat on, he didnt remember it being attached then either. It confuses me cause if thats the case I should never have passed the e-test I put it through, and shouldnt it run awful without a front o2? Anyways Ive decided to try to chase it down. The wires should be coming from the PCM correct? Does anyone know specifically what wires it is coming out of the PCM? I would assume the wires should be the same color as near the connector?
edit: currently have p0135 and p0132 for codes being thrown.
Old 06-23-2013, 01:42 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
the truck will run ok with no O2 sensor attached, but it should immediately set a CEL code/light (13x series O2 circuit). the truck will run from its default settings which might be a tad rich, but will run normal.
look for the O2 connectors on top of the transmission. one near the front, one near the rear.
Old 06-23-2013, 01:44 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
Originally Posted by dhvaughan
the truck will run ok with no O2 sensor attached, but it should immediately set a CEL code/light. the truck will run from its default settings which might be a tad rich, but will run normal.
I have p0135 and p0132 for codes. I searched the top of the transmission, there is no connector there.
Old 06-23-2013, 01:52 PM
dhvaughan's Avatar
dhvaughan
look in the transmission wiring harness. connector is normally attached to frame or body piece with a clip.
Old 06-23-2013, 02:10 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
I found this:
Its not the same as the end on my sensor though? Theres nothing else there. This is on the drivers side near the linkage to the shifter.
Old 06-23-2013, 02:21 PM
That should be it, shape is right, but, the wire colors don't look right.....
Old 06-23-2013, 02:27 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
Its circular though? Shouldnt it be squarish? Its got prongs on the inside as well if that makes any difference.
Old 06-23-2013, 02:30 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
I see tan and white wire there so that's the 02 plug. So you need the right 02 in the exhaust system thats all.
Edit: Or is it white and tan hmmm what's the drivers side plug look like?
Old 06-23-2013, 02:33 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
i think i know what happened. you ordered a ntk 23139 and you need a ntk 23506. i guess your truck is built to California emissions standards. do you still have your old o2 sensor kicking around?
Old 06-23-2013, 02:41 PM
Johnn123's Avatar
Johnn123
Johnn123 is offline
@merc: should there be more then one pre-cat sensor? i thought there was only the one? that photo was taken from the drivers side?
@cw: if it makes any difference, my truck was made in mexico, though i find it odd cause im in ontario canada though! is there a way to check what emissions standard it was built to? and no i dont dad threw them away thinking i didnt need them anymore
Quick Reply: Missing O2 Sensor Connector - Chasing it down
