01 ram 1500, P0601 code, replaced ecm, still won't start and same code - help!
Old 06-21-2013, 11:44 AM
GeorgiaberryMobley's Avatar
GeorgiaberryMobley
GeorgiaberryMobley is offline
Default 01 ram 1500, P0601 code, replaced ecm, still won't start and same code - help!
Our truck is a 2001 ram 1500, automatic transmission, v6 engine.
It is an annoying vehicle, but it is our only truck and we need it for work so I try to be patient with it LOL. A couple weeks ago, we started it, it drove about 4 feet and died and never would start again. Tried to turn over but wouldn't start.
We changed spark plugs (and some coil had been changed previously) and lo and behold it started right up. Ran for about 4 miles and died. Just like before, would not start, tried to turn over but just wouldn't start. Brother in law has code reader, and it had P0601 code. Replace computer.
OK - so I finally ended up ordering a reprogrammed replacement unit from Imperial Car Computer exchange - helpful guy on the phone but very very slow shipping OMG!!!! - ordered on tues - finally received part the FOLLOWING thursday (yesterday) ugh. Ridiculous with $20 for priority shipping.
We followed instructions and installed part - no change. Same not starting. Exactly the same. Same code.
What next? Phone help from imperial said "could be so many things... wiring issue, bad battery connection, corrosion in cables..." and that we could send them both units (theirs and our old computer) and they would compare programming to see if that told them anything. I am not eager to do that since their shipping is so poor.
Any suggestions? Thanks for your help. I really need it!
Georgiaberry
Old 06-21-2013, 11:46 AM
GeorgiaberryMobley
btw I have already scoured the local junkyards and had friends in other places looking as well for a cheaper replacement ecm/pcm and there are none to be found here....
Old 06-21-2013, 12:17 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
I am not sure but this might be the place that has a horrendous rep for sending out dead pcm's, others will post up. Get your money back fast and then start hunting elsewhere. DO NOT send them your pcm!!! you might never see it again. Post the pcm part number you are looking for.
Edit: Check out B&G for new/used pcm's
Here is /was a link seems there site is under construction. http://www.bgchrysler.com/
B&G Chrysler Specialists, Inc
25180 Ryan Rd, Warren, MI 48091, United States
Phone:+1 586-758-2003
Hours:
Sunday Closed
Monday 8:00 am – 6:00 pm
Tuesday 8:00 am – 6:00 pm
Wednesday 8:00 am – 6:00 pm
Thursday 8:00 am – 6:00 pm
Friday 8:00 am – 5:00 pm
Saturday Closed
Old 06-21-2013, 12:59 PM
GeorgiaberryMobley
thank you - I don't think this is the awful place, I read about that place on the forum, I think it is auto parts exchange - I think we had also called that awful place but they sounded flaky and we ordered from this Imperial Car Computer Exchange in North Carolina.
the module # is P56040264AF
Wow - I have learned a lot from reading through the forum after searching for other posts about this error code. Wish I would have done that before I ordered but I was just overwhelmed and could not figure out the problem. I had an idea for some reason that this was a part that I could only get from a dealer and so I never called my local auto zone ... turns out they can order the part - have a reprogrammed unit to me the next day, for about $60 less. Ugh.
And I am gathering from the forum that sometimes people have to try 4 or 5 different reprogrammed units before they get a good one. So frustrating. So since last night I have been thinking that we have a problem that is shorting out the new computer, but maybe the new computer is just not any good.
I can't bear to deal with the wait from this place in NC. If we can't track down any other problem this weekend I am going to order from autozone and see if that part works, then try to get a refund from the place in NC, I guess.
So - do I have this right? Once the computer throws the P0601 code, all you can do is replace the computer. Even if there is a short or some corrosion or a bad ground that affected the computer and you fix that, the computer won't just magically go back to normal. It has to be replaced? Do I grasp the situation?
Old 06-21-2013, 02:00 PM
merc225hp's Avatar
merc225hp
This might help you in your hunt,any of these pcm part numbers will work for your truck.
56040264AA
56040264AB
56040264AC
56040264AD
56040264AE
56040264AF
Latest version is 56040264AG
Old 06-21-2013, 03:15 PM
GeorgiaberryMobley
oh gosh - thank you. that is good to know.
Old 06-21-2013, 03:28 PM
gdstock's Avatar
gdstock
gdstock is offline
Check all the grounds. Battery to engine, battery to fender, battery to frame, engine block (rear passenger side) to firewall. Make sure PCM is tight and no corrosion around it.
Check connectors and make sure they acre clean and tight. Check connector on CTM.
Missing connection to PCM can fool it to think it is bad.
Old 06-21-2013, 05:24 PM
GeorgiaberryMobley
ok thank you - I will pass that on to my hubby and b-i-l. I know we did all the cleaning etc of battery cables and so forth that the instructions said to do but I don't know about all those grounds.
good place to start. thanks!
Old 06-21-2013, 06:45 PM
generaljr's Avatar
generaljr
generaljr is offline
maybe this can help, a friend of mine has a 2002 ram 1500 5.9, he had the check engine light on, we found the code for a bad PCM or ECM, not sure but what was the code, he didn't let me to try to fix his truck, he went to the dealer and bought a remanufactured one for $800+ instaled and reprogramed in his truck, it fixed the issues for a few weeks and suddenly began with multiple malfunctions NO BUS, intermittent stall-no start, faulty cluster lights, no turn signals, brake lights, well everything was weird at times, then he came asking for help at 9:00pm because of headlights acting weird, asked him what he did to the truck other than the ecm or pcm (Don't care) replacement, well the first symptoms began when he had somebody installing aftermarket audio-video system, Checked computer connections, grouns,battery and all were good, then moved to the audio system, pulled the dash to take a look at the cd player wiring and disconected the harness and kaboom all the warning lights went away, after inspecting the wires one at a time found that the illumination (Brown) wire was causing all the issues,just disconnected that one and everything is working as it should
Old 06-22-2013, 03:15 PM
GeorgiaberryMobley
Wow. I fear it is going to be some kind of problem like that. We haven't installed anything new like your friend did, but it seems like signs point to electrical issue and that is not good news to me, because I don't have anyone patient enough to check everything, and paying a mechanic for electrical work is $$$ because it takes so long to do all the checking.
We have historically had battery problems with this truck - not battery, I guess, but connection. Had to replace ends on both battery cables recently - that is a new thing we did?! and we always have corrosion build up on terminals - builds up so fast - has to be cleaned every couple of weeks it seems like or it gets to the point that the truck won't start. Battery always checks out ok at auto zone battery check.
Also replaced spark plugs day before this happened - and coil a few months ago. That's really all we have done. Before replacing coil the truck had been decelerating/shuddering when we were driving, like on the interstate. That problem seems to be fixed. Just reporting because I don't know enough to know if any of it matters...
Thanks for sharing that story, General - all these replies are getting me headed in the right direction I think.
Quick Reply: 01 ram 1500, P0601 code, replaced ecm, still won't start and same code - help!
