transmission parts swap
Old 06-20-2013, 09:56 PM
RedneckMagnumPower's Avatar
RedneckMagnumPower
RedneckMagnumPower is offline
Default transmission parts swap
So, im having problems with my 96 (5.9) ram transmission. It doesn't like to upshift and after researching, it appears either to be the transmission belt or the soleonoids. I have a scrap 98 Dakota (5.2) with a perfectly intact transmission. Would I be able to pull the parts from it, and put it in my ram. On sticker under the hood of the ram and in the glove box of the dakota, by transmission it has the same 3 letters, but I wanted to double check before I attempt this feat of mechanicary that I have never attempted in my life. Tanks in advandced.
Old 06-20-2013, 10:08 PM
gdstock's Avatar
gdstock
gdstock is offline
There is no belt in the transmission. Need to find out why it is not shifting, If both are 46RE transmissions, they will swap out. How is fluid? How long since filter changed? What upshift does it not like?
Old 06-20-2013, 10:10 PM
stewie01's Avatar
stewie01
stewie01 is offline
Old 06-20-2013, 10:17 PM
RedneckMagnumPower
I dont know why I said belt. I was talking to someone about an alternator swap and my mouth and hands got mixed up. It doesn't like to upshift past second after it is warmed up, and in town it isn't too fond of going to second either. on cooler days and on rainy days, when it tends to be cooler, it will shift just fine, so I think it has something to do with temperature.
I will definitaly check out that link and see what it says.
Old 06-20-2013, 10:19 PM
stewie01's Avatar
stewie01
stewie01 is offline
Also check fluid, truck at normal operating temp, transmission in Neutral.
Old 06-20-2013, 10:20 PM
RedneckMagnumPower
Another thing worth mentioning is that if I attempt to go full throttle, the transmission leaves gear and goes to neutral, which makes me look like a dick on the road blaring his pipes and then slowing down.
Old 06-20-2013, 10:21 PM
RedneckMagnumPower
Ive done that, and it is full, and a clean, red color.
Old 06-20-2013, 10:24 PM
gdstock's Avatar
gdstock
gdstock is offline
Have you checked the TV Cable adjustment?
Old 06-20-2013, 10:28 PM
RedneckMagnumPower
I don't know how to do that. Im not the most mechanically inclined. I can do minor maintenance. I also don't have the truck right now. I dropped the driveline and am waiting for a new yoke.
Old 06-20-2013, 11:12 PM
gdstock's Avatar
gdstock
gdstock is offline
Go to post #3 and click the link Stewie provided. Not difficult.
Quick Reply: transmission parts swap
