Shaking 95 Ram 1500
Old 06-18-2013, 11:40 PM
blcranford2's Avatar
blcranford2
blcranford2 is offline
Default Shaking 95 Ram 1500
Have a 95 Ram 1500 4x4 with 360 engine. Starts and runs fine at low and high speeds but shakes at 55 mph. will go away if I push the button to disengage overdrive. trying to find cheapest fix. any ideas?
Old 06-19-2013, 09:20 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Idea 1x - Unbalanced tires.....
Old 06-19-2013, 09:23 AM
HeyYou is online now
If it stops when you disengage O/D...... I would suspect engine problem. (blown plenum, clogging cat, trashed O2 sensors, fouled plugs, etc.)
Old 06-19-2013, 01:47 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
+1.... Read the plenum sticky.
Old 06-19-2013, 02:53 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
+2 on the motor route, but I would start with a comp or leakdown test before parts are purchased. See what shape the motor is in before you drop a coin on it. Post back your findings.
Old 06-21-2013, 10:08 PM
MrZabel's Avatar
MrZabel
MrZabel is offline
I have a 96 and I have a problem like that. My Check engine light is on and its the Crank Shaft Sensor. It shakes and its real bad in OD. That could be your problem.
Quick Reply: Shaking 95 Ram 1500
