trans to transfer case leak
Old 06-16-2013, 05:58 PM
bigaaron's Avatar
bigaaron
bigaaron is offline
Default trans to transfer case leak
98 dodge ram 2500 4x4 360 251k
Changing the oil this weekend I noticed there was a leak where the trans and transfer case mate. It has leaked on top of the skid plate so its noticeable, but wondering has anyone else had this issue? Searched the threads to no avail. Please help.
I checked the trans fluid level - is good.
Tcase - is hard to tell.
Old 06-16-2013, 06:01 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The seals are probably bad. There is an input and output shaft seals. Need replace if it's leaking between the two.
Old 06-16-2013, 06:12 PM
bigaaron's Avatar
bigaaron
bigaaron is offline
thanks zman just found the thread in the DIY.
How tough is it to pull the tcase out? How much time would it take the mechanically inclined back yard mechanic?
Is it ok to drive like this if I do not use the 4x4?
Is this one of those common problems we are always running into?
Old 06-16-2013, 06:19 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
R & R is about three hrs work. Keep the fluid topped up and it will last until you fix it, but oil spraying around under a truck is a mess and a hazard.
Old 06-16-2013, 07:04 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Having had this same problem, get it fixed. Mine was so bad I was having to add trans. fluid every 2 weeks. I had my trans and t-case serviced at the same time. Cost me $302 for the whole she-bang at a local trans shop.
Old 06-17-2013, 12:31 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
t-case is easy to remove and not that heavy. sheriff has a thread on it. pop off linkage, vac line. front drive shaft. 4 or 5 nuts at transmission. get your knee up under it and press it down.
how do you know which is leaking? trans or tcase?
Old 06-17-2013, 12:41 AM
joshpalmer27's Avatar
joshpalmer27
joshpalmer27 is offline
Having the same issues with my 98 1500. I'm taking it to a friend later this week to get the seal redone. He said that it would be a 3-4 hour process if I did it by myself.
Old 06-17-2013, 05:55 AM
bigaaron's Avatar
bigaaron
bigaaron is offline
thanks all
dvaughn - i think it is the trans simply because I recently completed the trans service, but have royal purple in the t-case. The leaking fluid is blood red. I simply looked at it said *&#% and finished the oil change.
Old 06-17-2013, 06:00 AM
bigaaron's Avatar
bigaaron
bigaaron is offline
is there any risk of cross contamination of the fluids? should I change both?
do I need to drain just the tcase? or both?
Old 06-17-2013, 11:41 AM
dodge dude94
Two things, put ATF4 in both, that way you have less fluids to buy and no, there isn't a real risk of contamination between the two.
Quick Reply: trans to transfer case leak
