Nothing stops working when opening d/side door
I have a 2005 Durango Limited w/5.7 Sudddenly when ignition is turned off nothing works as it should with drivers door open. Radio stays on, dome light does not come on, door ajar light not coming on. Even when door is unlocked manually and opened, factory alarm does not go off. Basically the vehicle is not seeing the door open. I figured it to be the door latch/actuator so I replaced that unit but all symptoms still exist. Any advice is appreciated.
Mirko.bigwood,
If you would like to review if there are any outstanding recalls on your vehicle you can check out the link I've posted below.
http://www.chryslercanada.ca/owners/...hp?brand=dodge
I hope you are able to get your concerns addressed, if you would like additional assistance looking into your concerns, please PM me and I'd be happy to help.
