Pinging under load/ aftermarket intakes manifolds
Old 06-13-2013, 01:53 PM
Caseyjordanmurry's Avatar
Caseyjordanmurry
Caseyjordanmurry is offline
Default Pinging under load/ aftermarket intakes manifolds
Hey all. My 5.9 magnum pings under load. I assume it is because the plenum cover is leaking. Its also using some oil and gas mileage has dropped. Since I will have to remove the intake to fix the leak anyways I was thinking of swapping out the keg for an aftermarket one.
Hughes clams their intake to out preform the Mopar ones. Is this true? they also say it will improve the mileage. true?
The Mopar P5007790 intake says it requires modifications to use. what needs to be modified? Can I expect improvements in power and mileage?
Hughes http://www.hughesengines.com/Index/p...p?partid=24773
Mopar http://www.jegs.com/i/Mopar-Performa...oductId=750418
Old 06-13-2013, 02:19 PM
stewie01's Avatar
stewie01
stewie01 is offline
I think the general consensus is to go for the Mopar M1.. There's a few members with the Hughes and a few with the Mopar. They'll probably chime in sooner or later.
Welcome to DF!
Old 06-13-2013, 02:22 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
I honestly can't think of any modifications needed. But either redneck or Whiteknuckle will chime in, as they both have M1s.
The problem that I see with the M1 is that they are out of production, Mother Mopar isn't making them anymore. So prices will skyrocket and they will become scarce. So get it while you can, because that leaves Hughes and Mr. Hughes apparently is an *******.
Old 06-13-2013, 03:48 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
I had the opportunity to pick up a good used M1 intake here locally off craigslist late last year. I passed on it, as the owner of the M1 intake stated that he lost a fair bit of low end throttle response with the M1 intake over the stock kegger intake manifold. I decided to perform the kegger mod and install a new plenum gasket, aluminum plate, bolts and washers. Fixing your plenum gasket on your existing intake should cure your pinging issue and help your fuel mileage, too..
Old 06-13-2013, 04:21 PM
stewie01's Avatar
stewie01
stewie01 is offline
WhiteNuckle rock climbs in his Ram and he loves the M1.
Old 06-13-2013, 05:45 PM
Adobedude's Avatar
Adobedude
Adobedude is offline
The M1 in the link is a 4bbl M1, it'll kill your low end, you want the 2bbl M1.
http://www.jegs.com/i/Mopar+Performa...07852/10002/-1
Old 06-13-2013, 08:16 PM
Caseyjordanmurry
why would the 4 barrel version kill low end over the keg? id figure the more directed airflow would increase the velocity of the air? Im new to this EFI stuff so help me understand.
Old 06-13-2013, 08:25 PM
dodge dude94
It requires more rpm to pull in more air to make the engine operate properly. Basically too much capacity for air, not enough air.
Old 06-13-2013, 08:38 PM
Caseyjordanmurry
that's where im kind of confused. Doesn't the keg have more capacity than the 4 barrel? The pictures ive seen with the plenum cover off looks like its just an open plenum with runners that suck from the open space. Is this inaccurate?
Old 06-13-2013, 08:52 PM
dodge dude94
No, that's right. The more open space means the air is moving at a slower velocity, which means it will run out of wind sooner.
Quick Reply: Pinging under load/ aftermarket intakes manifolds
