01 to 97 motor swap question
Old 06-01-2013, 11:35 AM
blazer01's Avatar
blazer01
blazer01 is offline
Default 01 to 97 motor swap question
motor is in,trying to get wiring done its a lot different my problem now is can't figure out where camshaft sensor/pick up stator plugs into anyone got a idea,its a 97 sst im working on
Old 06-01-2013, 12:22 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The cam shaft sensor plugs into the wire harness running along side the driver side valve cover, the harness under the injectors.
Old 06-01-2013, 12:38 PM
blazer01's Avatar
blazer01
blazer01 is offline
exactly where it was on my 01 ram,but harness is different on the 97 crank and oil pressure are there(different) but no cam sensor plug
Old 06-01-2013, 12:40 PM
It should be around in that neighborhood....
Old 06-01-2013, 12:52 PM
blazer01's Avatar
blazer01
blazer01 is offline
man i wish it was,i was thinking maybe 97 had different plug or something there are a couple 2 wire plugs there not used yet,but no unused3 wire plugs i will be working on it again after work hopefully someone here can figure this out
Old 06-01-2013, 08:23 PM
blazer01's Avatar
blazer01
blazer01 is offline
still no luck had a 98 to compare and it was like my 01 nothing like my 97 no cut wires or missing any from main harness still taped from factory together can't figure this out
Old 06-01-2013, 10:38 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
I think you need to get a pickup for a 97 motor. Rockauto has different part numbers for the years, so maybe a different plug end.
Old 06-02-2013, 12:02 AM
QuadCabLuv's Avatar
QuadCabLuv
QuadCabLuv is offline
They are. If I had known the year models before I wouldve said something. The plugs on alot of things changed in 98.
Old 06-02-2013, 08:02 AM
blazer01's Avatar
blazer01
blazer01 is offline
ok thanks guys,much appreciated,going by parts store hopefully don't have to be ordered
Old 06-02-2013, 08:15 AM
blazer01's Avatar
blazer01
blazer01 is offline
is there a fuse for the obd port no power getting there
Quick Reply: 01 to 97 motor swap question
