Help with power steering hose. Please.
Old 05-21-2013, 09:08 PM
RyanWilson's Avatar
RyanWilson
RyanWilson is offline
Default Help with power steering hose. Please.
04 Dakota 4.7 v8. Im having problems with leaking power steering fluid. (gushing out) I went though a whole quart in less than a hr. Ive looked on rockauto.com for the hose. All i seen is that they have the pressure hose which is not the one thats leaking. The one if im correct is the return hose im looking for. Does anybody know of some good sites i can try to find this hose? The hose im looking for has the clamp that can be losend with a screwdriver. Plastic hose attaches to the pump, down below it becomes metal and i believe i need a 16mm line wrench to take off. Ive been looking for 2 days now looks like a fix i could do. Just dont want to take to auto shop if not needed to. If there is something im missing let me know. Thanks for the help.
Old 05-22-2013, 02:35 PM
Blacknights's Avatar
Blacknights
Blacknights is offline
Give a picture, I think I know what your referring to but I want to be sure. I'm pretty sure the part only has one maufacturer
Old 05-22-2013, 06:07 PM
RyanWilson's Avatar
RyanWilson
I cant get the pic on here i have it saved to my desktop.?
Old 05-22-2013, 06:20 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Ryan, when you click "reply" you'll see the paperclip symbol along the top of the "message box." Click that and it will take you to an upload page.
Hope it helps.
Old 05-22-2013, 06:43 PM
RyanWilson's Avatar
RyanWilson
I cant get it onto here it says its downloaded.
Old 05-22-2013, 07:21 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Ryan, you have to click the "New Reply" or "Go Advanced" boxes to see the paperclip symbol. Once you click that it takes you to the upload page.
Once you upload it, it's there. It will attach as this post shows.
File Type: jpg
Old 05-23-2013, 06:52 AM
RyanWilson's Avatar
RyanWilson
heres the requested pic.
Im sure you tell which hose is leaking. Well this hose is plastic once it reaches the steeriing pump, its attached to the pump with a clamp like is shown in this pic. hope this helps with helping me.
File Type: jpg
Old 05-23-2013, 08:04 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
That looks like a poor mans patch of a hole in the tubing to me its not supposed to be there.
I don't know your engine and power steering so you will need to wait for other people to give you the best answer on how to replace it.
Look at the pic as to what part you will need
The other line is the return line low pressure you may have a cooler in line or not is my understanding
Old 05-23-2013, 09:12 AM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
If its the low pressure line that's leaking you may need to go to a dealer for the part or get the rockauto Power Steering Cooler Line and use the part shown as a replacement and make do.
Or cut out the rotted out part of the line and use some tubing and two clamps if you know what I mean?? That is if its the low presser line??
Old 05-23-2013, 10:38 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Glad you got the picture.
Like '98 says, that's a patch job - and a bad one to boot.
Looking at the amount of corrosion/junk around the lines, replace them. Check your dealer if you want the same style.
Quick Reply: Help with power steering hose. Please.
