3rd Gen Durango 2011+ models
Directions on replacing fog lights?
Old 05-16-2013, 12:49 PM
Hemibuck's Avatar
Hemibuck
Hemibuck is offline
Default Directions on replacing fog lights?
Does anyone have a link of the fastest and easiest way to replace the fog lights for a D3 R/T? I have my new LED's I want to install today. Thanks!
Old 05-16-2013, 12:55 PM
coldsteel's Avatar
coldsteel
coldsteel is offline
Jack up the front end or pull up on some ramps, crawl underneath the fascia, reach up in the space between the fascia and underbody shield and remove them by squeezing the tabs.
Old 05-16-2013, 01:28 PM
CMil527's Avatar
CMil527
CMil527 is offline
U don't need a jack at all just lay on the ground to access the back of the fogs, very simple swap!
Old 05-16-2013, 01:39 PM
SlvrShrk's Avatar
SlvrShrk
SlvrShrk is offline
Yeah...what they said...I used ramps...easy install (unless you have shovel hands from what I hear) LOL
Old 05-16-2013, 02:06 PM
SAN DOG 34's Avatar
SAN DOG 34
SAN DOG 34 is offline
You don't need to jack it up but if you have bigger than average hands like myself, it will take some cuts and bruises on hands to do the swap. Remember is your replacing with aftermarket fogs, you most likely will have to dremel off the clips or stub walls on the oustside diameter of the bulb.
Old 05-16-2013, 02:23 PM
SLAINTE06's Avatar
SLAINTE06
SLAINTE06 is offline
No Dremel required, mine fit with no problem a few weeks ago and with no jacking up. But yes shovel hands not recommended, but really a 10 min install if that
Old 05-16-2013, 02:30 PM
phoneguy589's Avatar
phoneguy589
phoneguy589 is offline
I used a utility knife to shave down the single notch so that it was almost smooth and it popped right in.
Old 05-16-2013, 04:16 PM
Hemibuck's Avatar
Hemibuck
Hemibuck is offline
Thanks guys...going to give it a shot without the ramps.
Old 05-16-2013, 04:45 PM
Hemibuck's Avatar
Hemibuck
Hemibuck is offline
"Staples button....that was easy!" Nice I think they give it a daytime running light effect now. I did have to trim down the tabs on the one side and the wiring harness doesn't "snap" in place but they're not moving.
Old 05-16-2013, 06:33 PM
FSTDANGO3's Avatar
FSTDANGO3
FSTDANGO3 is offline
Same here...It doesn't snap in but they are solidly in there.
Quick Reply: Directions on replacing fog lights?
