3rd Gen Durango 2011+ models
Air conditioning not cold
Old 05-13-2013, 08:19 PM
jeffsmachine's Avatar
jeffsmachine
jeffsmachine is offline
Default Air conditioning not cold
2013 RT with less than 3,000 miles.
It was 100 deg today, and air set all the way down to "LO" with fan on full speed, car still not cool enough.Girlfriend who normally doesn't like air too cold, was warm too.
I've suspected there was a problem earlier ,because I would have to turn the air on full blast to cool the car on a 75 deg day.
Anyone else have any problems with theirs?
Any Techs out there? What temps should I see coming out the vents?
Old 05-14-2013, 12:43 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
It should be between 48-65 degrees Fahrenheit depending on the outside ambient temp. My suggestion is to let the dealership test if for you if you think it is not operating up to snuff.
Old 05-14-2013, 02:26 PM
jeffsmachine
Thank You Chris, Ill get a thermometer reading today.
Old 05-14-2013, 02:39 PM
DodgeCares's Avatar
DodgeCares
My only question would be, have you tried using the recirculation function during times in A/C mode with high outside heat?
Old 05-14-2013, 05:53 PM
jeffsmachine
Outside air 87 deg
Air at vent after 10 min. = 64 deg
Yes, I always use the recirc mode , and it is cooler that way , but 64 deg at the vents is not cooling the car enough
Old 05-14-2013, 06:36 PM
woblik's Avatar
woblik
woblik is offline
64 is not nearly cool enough. It should be in the low 50's.
Take it to the dealer. If its a 13, should def be under warranty
Old 05-15-2013, 10:23 AM
2012sxt's Avatar
2012sxt
2012sxt is offline
I had to take my 2012 v6 DD in because of not cooling and the problem was the freon was underfilled from the factory. When they evac all the freon it came up short from what it was supposed to be. They refilled it and topped it off and has been fine ever since
Old 05-15-2013, 11:35 AM
jeffsmachine
Thanks Guys
I'm sitting at the dealer as we speak
Old 05-15-2013, 01:25 PM
DodgeCares's Avatar
DodgeCares
An overfill situation could cause the problem as well. Best to have the dealership take a look in this case.
Old 05-15-2013, 03:44 PM
jeffsmachine
Success
Air at vent now 50 deg.
Dealer said it was low on freon.
I looked up and saw a black D being washed, asked if they wash all cars, Guy says NO, we ask first. Me.....good because I don't want mine washed.
Get a closer look.....dang, it's Mine. Now I need to polish out the swirl marks LOL
Quick Reply: Air conditioning not cold
