Manual 1st Gear Bucking
Old 05-13-2013, 06:43 PM
maillouxb's Avatar
maillouxb
maillouxb is offline
Default Manual 1st Gear Bucking
99 Dakota
Started having issues about 4 weeks ago with my 5-speed stick. When I let up on the clutch in 1st gear only, the truck starts bucking and shuttering until I get it up to speed. Gears 2-5 are just fine when I am driving along. It literally feels like something on the bottom of my truck is going to fall out. Could this be a bad clutch assembly or some kind of adjustment?
History:
March 2012, clutch crapped out and had it replaced.
March 2013, clutch crapped out, again, 3 days before its 1-year warranty expired (go figure); had new warranty parts installed.
Any suggestions?
Old 05-13-2013, 07:01 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
What engine do you have?
Does it seem that the engine is missing or is it related to the clutch? Can you slip it a bit to smooth it out?
How are the motor mounts?
Old 05-13-2013, 07:05 PM
maillouxb's Avatar
maillouxb
3.9L
Yes, once I get about 1/2 way up on the clutch, it will smooth out. If it was the motor mounts, wouldn't it do it for all the gears?
Old 05-13-2013, 07:12 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Are you the original owner? Ever have the clutch replaced?
Its probably new clutch time bucking is a good indication
Get a new Clutch Slave Cylinder at the same time that will save you some pain.
Old 05-13-2013, 07:21 PM
maillouxb's Avatar
maillouxb
Clutch has been replaced 2X; all new parts. It worked great when I got it back from the shop in March, up until the end of April.
Old 05-13-2013, 07:27 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
Did they install a new pressure plate or used rebuilt as I had the same thing happen to me bucking from a new clutch job ended up being a poor grade cheap rebuilt clutch pressure plate.
They will fool you and say its new but they mean new rebuilt.
It could be a bad pressure plate also its warped from a bad install or just a bad warped plate from the factory.
I always SAY I WANT NEW (FACTORY NEW) not rebuilt they are CRAP
Old 05-13-2013, 08:08 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Bad motor mounts would be more pronounced starting off. That's when the most force is on the transmission/engine.
A bad clutch disk can also cause this. There are springs to help "dampen" oscillations. Fluid contamination of the flywheel (are you leaking oil) can do this as well.
Something else to consider, Dodge does NOT recommend resurfacing the flywheel. It's not flat. Was it refaced?
Old 05-13-2013, 09:16 PM
maillouxb's Avatar
maillouxb
How many motor mounts are there? Where do you locate them? How do you tell if they are bad? I will check this 1st before I take it back to inspect the clutch disk or flywheel at the shop.
Thanks for all the great feedback.
Old 05-13-2013, 09:33 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
There are two motor mounts, one on each side of the block. There is also a mount by the transmission. Look for torn or oil soaked rubber.
I'm betting it's more of a clutch issue though.
Old 05-13-2013, 09:46 PM
maillouxb's Avatar
maillouxb
What do I suggest to tell the mech shop? Should I claim it's possibly the clutch disk or flywheel?
Quick Reply: Manual 1st Gear Bucking
