Lower engine noise/ need assistance troubleshooting
Old 05-11-2013, 05:48 PM
wtfwhosmike's Avatar
wtfwhosmike
wtfwhosmike is offline
Default Lower engine noise/ need assistance troubleshooting
Ok, so I have used all the great info I have gotten on previous posts and have not fixed my problem yet. The noise used to be quieter and harder to track but now its been pinpointed to the lower engine. Ive added a video of the noise, ANY help at this point would be greatly appreciated this is my daily driver
Old 05-11-2013, 06:38 PM
gdstock's Avatar
gdstock
gdstock is offline
Not good. Remove pan and have a peek inside.
How is your oil pressure?
Old 05-11-2013, 06:46 PM
wtfwhosmike
oil pressure runs a bit high til truck warms up then seems to run a bit low...
Old 05-11-2013, 06:52 PM
gdstock's Avatar
gdstock
gdstock is offline
Remove plate from front of trans by Torque Converter. Check the bolts and make sure one of them is not backing out. Also could be rod, or crank hitting oil pump pick up.
Pretty definitive knock going on.
Old 05-11-2013, 08:27 PM
00SilverRam's Avatar
00SilverRam
00SilverRam is offline
That sounds like a rod bearring. Or at least the rod hitting something.
Old 05-11-2013, 08:29 PM
kejobe's Avatar
kejobe
kejobe is offline
I second a rod bearing. Or third? Either way.
Old 05-11-2013, 08:34 PM
wtfwhosmike
So I pulled oil pan and checked flex plate bolts while I was under there. Nothing looks serious to me, then again im fairly new to this. One thing that did seem a little off was I found small pieces of gravel in my oil pan as well as on the oil pump pick up screen. Any ideas where i need to go from here. I took a few pics ill post as soon as i get them uploaded to my computer
Old 05-11-2013, 08:52 PM
wtfwhosmike
Old 05-11-2013, 09:01 PM
gdstock's Avatar
gdstock
gdstock is offline
Make sure that rotating pieces do not hit pump or pick up. Try to shake the rods around on crank by hand. Do you feel any movement? Now use a piece of wood to see if there is any slack on the rods. Do not use anything metal.....
Old 05-11-2013, 09:40 PM
wtfwhosmike
I dont really see anywhere it was hitting the pick up at all. I tried shaking the rods by hand. There is as little movement side to side on all of them around the shaft but no movement or slack in the rod tself
Quick Reply: Lower engine noise/ need assistance troubleshooting
