air horn install
Old 05-06-2013, 02:34 PM
kendawg's Avatar
kendawg
kendawg is offline
Default air horn install
I have a set of Hadley air horns I want to install on my 2013 Ram 1500. On my old truck I tapped the horn circuit so no additional switch or button had to be installed to activated the horns. Where is the horn located on this truck??? I know what a traditional horn looks like and I can't find anything that resembles one.
Old 05-06-2013, 03:02 PM
2012sxt's Avatar
2012sxt
2012sxt is offline
on my durango they are behind the grill and look like two flat round things pressed together...not like the old school horns
Old 05-07-2013, 02:01 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
REMOVAL
  1. Disconnect and isolate the negative cable from the battery.
  2. Remove the left front fender wheel house splash shield from the vehicle.
  3. Locate the horns and mounting bracket on the outboard side of the left front fender load beam above the left front fender wheel house.
  4. Disconnect the headlamp and dash wire harness connector for the horns (2) from the horn connector at the back of the rearward horn.
  5. Remove the screw that secures the horn mounting bracket to the load beam.
  6. Remove the horns and mounting bracket from the load beam as a unit.
Quick Reply: air horn install
